Upside down yoke?
N419A
Upside down yoke?
Post by N419A »
I saw some photos of 170's with the yokes upside down. Can you just pull the bolt below and rotate the yoke 180 and replace bolt. Being 6'4" the lower part of the yoke hits my legs and even worst when bundled up for winter flying.
Thanks, Paul
N2865C
Post by N2865C »
I've never done it on a 170, but I have done it on a 120 that has the same basic setup. I think it should work fine.
N2865C
Dave Clark
Post by Dave Clark »
Only if you stand on your head in your seat for takeoffs and landings :P
A retired United pilot friend Spanky Allen, now deceased, actually did this on the job. Getting fed up with the terrible landings his new kid copilot was doing he reportedly told him he could land the plane better than him upside down. Memory fades but I think he stood on the seat backwards and landed looking through his legs. True story.
I'm sure you can reverse the yokes and I've actually seen it done. I don't know about the legality of it. It looks rather weird also but hey if it helps you then it makes sense.
N92CP ("Clark's Plane")
1953 C-180
lowNslow
Post by lowNslow »
Just remove the aft bolt at the universal joint (Item 12 in your parts diagram) rotate 180 degrees, reinstall bolt.
Upside Down Yokes
Post by 170C »
Did the same thing in my C-140 to give me more leg room. Worked great, didn't worry about "legality" and it didn't look weird.
Harold Holiman
Post by Harold Holiman »
My 180 has the yoke turned up and it is much more comfortable in this position to me. When I had my 170, it was also turned up.
Harold
N92CP
N419A
Post by N419A »
Thanks for the input it will be done next time I'm in the hanger.
Thanks, Paul
