How to locate Final Aircrash Report
MoonlightVFR
Post by MoonlightVFR »
I am trying to locate the FAA 's final report on Aircrash that occured on 07/26/2006.
Aircraft was DHC -6 Twin Otter 100 that crashed on takeoff. Skydiving company that operates near my home airport of St.Clair, MO .
I put in the A/C N203E and date of 07/29/2006 into google and get Otter reports from all over, newspaper coverage of the crash and prelim
reports.
Can anyone direct me to a site that contains the final file
regards
gradyb
gradyb, '54 B N2890C
pif_sonic
Post by pif_sonic »
God forbid we should ever be twenty years without a rebellion. ***Thomas Jefferson***
flyguy
ntsb synopses
Post by flyguy »
This is probably the easiest of all - -
http://www.landings.com/evird.acgi$pass ... -ntsb.html
The NTSB has not yet released a final report on N203E's most recent accident. It's not uncommon for final reports on fatal accidents to take 2 years or more. Incidentally, that same airplane was involved in a mid-air with a helicopter during a movie shoot at California City, CA in 1990. Both aircraft landed safely.
flyguy
HERE IS THE PRELIM
Post by flyguy »
NTSB Identification: CHI06FA210
14 CFR Part 91: General Aviation
Accident occurred Saturday, July 29, 2006 in Sullivan, MO
Aircraft: de Havilland DHC-6-100, registration: N203E
Injuries: 6 Fatal, 2 Serious.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On July 29, 2006, about 1345 central day light time, a de Havilland DHC-6-100, N203E, piloted by an airline transport pilot, sustained substantial damage on impact with trees and terrain during takeoff from runway 24 (4,500 feet by 75 feet, dry concrete) at the Sullivan Regional Airport (KUUV), near Sullivan, Missouri. Witnesses observed flame emitting from the right engine during the takeoff. The skydiving flight was operating under 14 CFR Part 91. Visual meteorological conditions prevailed at the time of the accident. No flight plan was on file. The pilot and five passengers sustained fatal injuries. Two passengers sustained serious injuries. The local flight was originating from KUUV at the time of the accident.
A witness on the road at the end of the takeoff runway, in part, stated:
I was riding my bike on AF Highway approximately 1:30 or 1:45
pm on the afternoon of July 29, 2006. I was at the end of the runway
and heard the sky diver plane, and as I always do, I stopped and
watched it take off. It was about 150 feet in the air and just about at
the end of the runway when all of a sudden, there was (Poof) sound
and the right engine was engulfed in fire. The plane kept going and
was turning to the right. It was not gaining any altitude but staying
about the same height, the right engine was just barely turning at that
time and then the trees blocked my vision. ... I listened for about
fifteen seconds and heard a crunching sound and I looked for smoke
but there was none.
Another witness, who was in her backyard pool area adjacent to the accident site, stated that the airplane was low and flying straight and level towards her. She said that the plane nosed over. She and her father were the first on-scene and placed the 911 call. She reported that local emergency medical service arrived within minutes.
The airplane impacted trees and terrain behind a residence and came to rest vertically nose down against a tree about a half mile north west of the end of runway 24. The empennage separated from the fuselage and remained connected to the fuselage through the control cables. The right wing was separated from the fuselage at the wing root. The right flap was extended. The left wing was separated from the fuselage at its rear spar. The left wing's forward spar remained attached. The left wing's flap was retracted. The outboard section of both wings exhibited rearward crushing. A wooden pole that supported the electrical service to the residence was found on the ground. The electrical wires from the pole were found resting on the left wing. The airplane's nose and cabin were crushed rearward. The left engine and propeller separated from its wing and were found resting on the ground under the left wing engine nacelle. The right engine separated from its wing. The right engine's exhaust section separated. The forward exhaust section, propeller gear box, and propeller were found about three feet west of the right engine nacelle. The remainder of the right engine was found about ten feet west of the right engine nacelle. The smell of fuel was present at the site.
An on-scene investigation was conducted. Flight control cables were traced from the flight controls in the cockpit to each flight control surface. All breaks in cables were in overload. Flight control continuity was established. Engine control cables were traced from the cockpit engine controls to each engine. All breaks were in overload. Engine control continuity was established. The forward fuel cell was torn. Fuel was found in forward and aft fuel cells. The engine and propellers are being retained for further examination.
At 1253, the recorded weather at the Rolla National Airport, near Rolla, Missouri, was: Wind 290 degrees at 9 knots; visibility 10 statute miles; sky condition few clouds 5,000 feet; temperature 35 degrees C; dew point 20 degrees C; altimeter 30.04 inches of mercury
MoonlightVFR
FINAL AIR CRASH REPORT
Thank you for your help.
I just did not realize thatt it could take two years plus for a final report.
regards
