avcon 180 performance stats
wwingsong
Post by wwingsong »
Hi, I just sold my pa 12 -150 and am buying a 1950 Cessna 170 with a avcon 180 conversion and cannot seem to find any performance stats, anyone give me a steer? Thanks from Minnesnowda
Re: avcon 180 performance stats
You can use the search routine to find other discussion threads on this subject, but I believe you'll come up wanting. Here's a msg I posted about the subject:
http://www.cessna170.org/forums/viewtop ... 835#p16835
Unfortunately (or Fortunately, depending how you prefer to look at it) the C-170 is something less than a high performance airplane, notwithstanding the various types of engines that may have been installed over its long service life.
On almost all the airplanes I've observed there is , somewhere on the panel, or nearby, a knob attached to a bowden control terminating on the carburetor throttle arm.
This knob, when pushed forward in flight, increases engine noise, makes the airplane climb, or go faster.
Inversely, when this knob is pulled back, engine noise is reduced (sometimes drastically), the airplane slows down and has a tendancy to fallout of the sky.
From my extensive experience, forget all that other paper work such as POHs, TDCSs etc.. The above is all you really need to know to successfully fly the Cessna C-170 series airplanes.
flyguy
Post by flyguy »
blueldr wrote:Unfortunately (or Fortunately, depending how you prefer to look at it) the C-170 is something less than a high performance airplane, notwithstanding the various types of engines that may have been installed over its long service life.
MY ESP RIENC - - The wheel (stik) has lots to do with that too - - YA KNOW! Pull back to go up - -Pull way back to GO DOWN RAPIDLY!
If you're looking to purchase anything with the Avcon conversions, make certain it has the complete paperwork for the modification including STC document, Form 337, and installation instructions. (This is actually important for any STC, but particularly so for Avcon as those folks (Williams/Udall) do not enjoy a reputation for responsiveness or support.)
trake
Post by trake »
Its gonna be virtually identical to a 1963 Cessna P172D 'Skyhawk Powermatic' which had the geared 175 HP Continental engine and a CS prop. A google search might turn something up.
Tracy Ake
1955 cessna 170b
sn26936
N2993D
