170A Flaps Like the 170B?
lovetaildraggers
Post by lovetaildraggers »
Does the 170A have the 40 degree fowler flaps like the 170B?
canav8
Re: 170A Flaps Like the 170B?
Post by canav8 »
No the 170A is a straight wing with no dihedral and no fowler flaps like the B model. Doug
52' C-170B N2713D Ser #25255
The 170 & 170A has "split" flaps.....not"semi-fowler" flaps, such as the B-52 model.
N2255D
Post by N2255D »
gahorn wrote:The 170 & 170A has "split" flaps.....not"semi-fowler" flaps, such as the B-52 model.
George, I always thought the 170/170A had plain flaps. Aircraft like the Gooney bird (DC3/C47) had split flaps.
Walt Weaver
Spencer Airport (NC35)
The small less effective A model flaps also drop to 50 degrees at full extension.
mekstrand
Post by mekstrand »
The 170 & 170A do not have split flaps. They have small plain flaps. The A model has 50 degrees of deflection and are not as effective as the later (much larger) fowler flaps on the B model aircraft.
Saying that ...I own an A model. I've wished I had more engine several times, I've never needed more flap.
Marshall
bagarre
Post by bagarre »
By comparison, the 195 has split flaps
In the link above provided by Aryana, it looks to me that the split flap is the closest to what the c-170 and the C-170A have. they certainly are not like the "Plain Flap" picture shows. I do have to admit that none of the above pictures seem to be exactly the same as the flaps through the A model and as on the 190/195.
canav8
Post by canav8 »
A Split flap is one where the top surface of the wing does not deflect it is fixed to the rest of the wing while a the trailing edge splits and a flap comes down from underneath. Here.
mekstrand
Post by mekstrand »
The 170A does not have the same flap design as the 190/195 series aircraft. The 170A has a PLAIN flap. Here's what a 170A flap looks like for those that need a refresher. The aircraft in the photo is our 170A.
Marshall
mekstrand,
Thanks for enlightening me. I would have sworn that the A model used a split flap. Did the straight C-170 have the same flap? I seem to remember that there was a straight C-170 parked on the Ramp at Rancho Murieta and the flaps used to blow down when the Helicopters hover taxied behind the parking line.
mekstrand
Post by mekstrand »
Blueldr,
Tha straight 170 has similar plain flaps (like the 140). The early plain flaps are held up by a single spring which is the only thing that keeps them up while the aircraft is on the ground. The spring is very light and gusty winds can blow the flaps around quite a bit if they are not properly secured.
blueldr wrote:mekstrand,
Yeah....I don't know what I was thinking when I wrote that.
I knew better, but misspoke and left, and forgot I even visited this thread.
(In fact, clearly I didn't even proof read that post before leaving,...I did not mean
B-52...... I meant B- model, beginning in 52. :roll:
Thanks, mek and Aryana for clarifying.
bagarre
Post by bagarre »
I wasn't trying to say that the 170A and 195 have the same flap design.
Only that, by comparison the 195 does have split flaps. To show the difference.
