Bruce Fenstermacher wrote:Darn it thought I might have found some paperwork.
I'd put one 8" on and if I needed it then I'd get a second or I'd even try it with a 4". The 8" and 4" will be a slightly different length and shape only noticable by most when they are next to each other. To bad these 4" venturi aren't worth anything, seems everybody has a few in their hanger.
Did I miss something? How did a mis-matched set of venturiis get into the discussion?
I believe a mis-matched set will only diminish the performance of the pair, neither achieving their potential.
I'm concerned the more powerful venturi will likely "backwash" the smaller, and will see the smaller as a "leak" in the system.
Cessna had dual,
identical venturiis connected in "parallel" for their instrument airplane kit, to drive an AN DG, and and AN Horizon.
Here's how they did it:
To see a larger version, and other details, click on the #2 link below.
If a search is made in these forums, in two seperate threads, I talked about "upgrading" my panel to the "super" venturiis, because I wanted to assure plenty of vacuum existed for an additional (modern) 3-1/8" pictorial gyro.
1.
http://www.cessna170.org/forums/viewtop ... on+project
2.
http://www.cessna170.org/forums/viewtop ... +venturiis
Prior to the mod, my dual, standard venturiis produced about 4" of vacuum at 7500' MSL cruise. Lower altitudes produced a bit more, up to 5".
After swapping them out to super-venturiis, adding a third gyro (the new horizon) and an interconnecting manifold, and regulator, I see 4.5" at all atlitudes from S.L. to 7500', presumeably due to the added regulator. (I've not tried it above that yet.)
I'm certain that dual super-venturiis will prove satisfactory with whatever two gyros you have installed, and that's what I"d recommend.
Charley, I suspect Cessna put them both on the starboard side for a reason. There have been operators who noted reduced efficiency with those mounted on the port side. (Prop-swirl effects perhaps ??) Anyway, I've had excellent service from my right-side venturiis, and absolutely refuse to consider downgrading to a vacuum pump. (That should re-liven this discusson.)
