Vertical Stab Cessna logo on '55
Re: Vertical Stab Cessna logo on '55
While your making exact duplicates from the aircraft, the Association library could use a copy. (Don't forget to put a scale on the template so duplicates can be checked for correct size) :wink:
oz502man
Post by oz502man »
Check these out...http://www.cessna170.org/forums/viewtop ... =15#p74873
They can be resized or edited as required and cut from vinyl paint mask. These images are all traces from the pictures in those posts so I can't guarantee the accuracy, but they will be pretty close. They certainly looked the part on my plane when done.
edit: the 'Cessna' font with the bird is not an exact match for the original it was the closest I could get at the time.
Work : AT502B
Play : '51C170A
jwpalmer
Post by jwpalmer »
If you haven't already solved the logo problem, Ive had great success working with Paul Howe at Moody Aerographics (http://www.moodyaero.com). With a good photo he can reproduce either a peel and stick or a paint mask that will fit perfectly. He "downsized" a '05 182T paint scheme for my 150K including tail logos and I was very happy with both the fit and the price.
rusty
Post by rusty »
Arash,
My airplane still has the original "CESSNA" on the door. However, it does have the letter 'R' with a circle around it reffering to the trade mark for Cessna. The R is located slightly below the A in Cessna. Keep in mind that it is very small and probably not visible in many pictures, but it is there. The "R" decal at last check was still available from Cessna. I did order this decal, but it was bigger than the original 1955 one.
I still have the original 170 script on the airplane and I will send you a traced copy of it when I get the airplane back. I hope to have it back within the next ten days. All the copies I make, I will send them to Bruce as well for the library information.
In regards to your 170 emblem for the insturment pannel, my hangar neighbor had a 56 172 with that emblem in it as well. You might want to check early 172's for that.
Hope this helps you.
Rusty
N2935D
Ryan Smith
Post by Ryan Smith »
Arash,
George posted a scanned copy of a 170 script stencil a while back. I'll try to dig it up, but I also have it saved on my computer. The only thing that would be missing would be a scale to denote the correct size. I normally don't trust a scanner to provide a 100% accurate representation of something being full-size.
I had thought about tracing it and putting it into a vector format for the use of the Association like I did with the 1952 B model graphics.
Ryan I just came across Georges scan of the stencil. Problem with it is as Rusty points out, there is no scale so it would be difficult to assure it was duplicated at the correct size.
Let's see what we get from Rusty. I may recruit you, Ryan to convert it to vector. :wink:
I've got quite a few original Cessna stencils and water-transfer decals. I'll try to devote a little time to getting them duplicated so others can have access to them. Any advice on the project is welcome.
