the rooster is a crowin, the grass is a growin;my airplane cranked and ran; i am a happy man
one curtiss 1/8 npt relaced in left wing;no more leek
put back what you take out
Fuel strainer (fuel drain) replacements
- MoonlightVFR
Re: Fuel strainer (fuel drain) replacements
I read all the posts and it was becoming a STRAIN.
Now I will have to measure door clearance to wing tank Drain.
Regards
Regards
gradyb, '54 B N2890C
There is more than one 170 with relief slots in the top of the door to clear the fuel drain.MoonlightVFR wrote:I read all the posts and it was becoming a STRAIN.
Regards
Bruce Fenstermacher wrote: There is BTW an STC to install a quick drain in the fuel selectors of B models but no other models. A problem with this STC if you have one of the first 18 B models you have the A model fuel valve. A quick drain can still be added but it won't line up with the hole as provided in later B models. When I queried the owner of the STC wondering why he limited the STC to B models he said because they had different fuel selectors. When I pointed out 18 B models had the early valve and would be covered by his STC and therefor all the A models should or could also be included, he didn't care.
That explains it!! All this time, I thought my plane was bent or something 'cuz the drain dosent line up with the hole
According to what I see, the different part number is really the difference in the diameter of the threads that go up in the. As mentioned, I read posts that says CAV170, but mine have CAV160 in them. I had ordered the 170, but it was way too small for the hole in the tank. I guess I am wondering why there would be different sizes?
No, only the first 18 B models have the A model early fuel selector. David yours should have the later model fuel selector. Still doesn't mean the holes will line up.bagarre wrote:Bruce Fenstermacher wrote: There is BTW an STC to install a quick drain in the fuel selectors of B models but no other models. A problem with this STC if you have one of the first 18 B models you have the A model fuel valve. A quick drain can still be added but it won't line up with the hole as provided in later B models. When I queried the owner of the STC wondering why he limited the STC to B models he said because they had different fuel selectors. When I pointed out 18 B models had the early valve and would be covered by his STC and therefor all the A models should or could also be included, he didn't care.
Because people had to go oversize when they messed up the original threads I'm thinking.BlakeinAlabama wrote: I guess I am wondering why there would be different sizes?
- blueldr
I have found that most of the stripped wing tank fuel drain bosses have been repaired by tapping the boss out to a
1/4" NPT thread. One must then use extreme caution when installing a tapered thread, steel bodied, drain valve in the aluminum boss lest he really ruins it. It is best to use a petroleum compatible sealant on the threads and not over tighten the valve to stop leakage.
