While the majority of us do not operate under Pt 135, FAR 135.165 (para f) requires that aircraft operating (under IFR) have two microphones and two headsets or one headset and one speaker. I'll bet your specific operation has an exemption, or you have two headsets, or... it's recognized that helicopters are not aircraft.Bruce Fenstermacher wrote:George, none of the helicopters I've ever flown part 135, have had a cabin speaker or a microphone. Can you explain that? Or maybe, just maybe a speaker and a microphone is not required.
My 170 does not have a speaker. It is not on my equipment list.
I copied and pasted the TSO reference directly from a google search, and although not relying upon that as the primary msg in my posting, I thought it interesting so copied/pasted it. It was from faa.gov but I do not see it in the TSO David posted either.
I looked back at my "google search" and do not see the reference.
The specific ADS-B solution chosen by each operator will likely differ, but some may require a cabin speaker and that is why I posted that comment (taken directly from faa.gov also.) If your Equipt List has no speaker listed then it does not have to be operational. BUT....that comment relies upon a complete/correct list. Many MELs are incomplete and the speaker was included in original equipment lists which have been improperly replicated (leaving the speaker off the list without an approval basis.) If your original Equipt LIst (from Cessna, or from a previous avionics installation) should have included the speaker as an item, then it must be either operational, or removed under some basis of approval, unless you have a MEL specifically assigned to your aircraft allowing it's inoperative status.
My intent in the previous post was not to insist that all aircraft must have a speaker. It was intended to suggest that good operating practices consider the safety features of either a speaker, or a suitable substitute (such as a separately-wired, redundant headset, etc.)
