These landing technique threads are always my favorites!
First I will cover what I do in my A model.
Takeoffs: Yoke into the wind, rudder to keep it straight, lift the tail when it becomes light, then lift off into ground effect somewhere after 50mph when she is ready to fly. Pop two notches of flaps if I want to elevator up, or clear obstacles (or pretend to clear obstacles). Usually as soon as the airplane lifts off it accelerate fairly quickly over 60 mph.
Landings: 80 mph on downwind, pull two notches (20 deg) abeam point of landing and reduce throttle to about 1300, pull third notch (40 deg?) turn base and adjust throttle to try to hit about 70 mph and 800 AGL at midpoint of base turn. This is the point where I vary techniques between the pull it all the way to idle to or keep power on. Notice I didn't say where I turn base, if it is going to be an idling approach I turn much closer, if a powered approach I turn when the touch down point is aft 45 degrees. I am from the school that believes an engine is more likely to conk out when you reduce power, but I also practice the no power approaches for engine out practice. Sort of walking the fence
. I digress... from the base turn I pull the fourth notch (50 deg?) and slow down to from 55 to 65 mph depending on how short I want to land and gust conditions. Wing down top rudder for alignment down final and then usually three point. For me that is the best way to land in cross wind conditions. If I am practicing wheelies I usually keep power at about 1200 and approach at 65 mph. I try to just fly the airplane on and rock the yoke forward the moment the wheels touch. The technique that someone mentioned of trimming at a higher airspeed works great at preventing bounces.
Now for my caveat... wheel landings are generally taught as the cure all for crosswind landings, what I have found is that wheelies take a little more finesse close to the ground, and when there are high crosswinds there is usually turbulence. Maybe it is easier in a B model, maybe it is just a quirk in my flying but a wheel landing is the last thing you will see me doing in high crosswinds.
I'm not sure I can agree with the technique of flying the airplane down at an 80 mph low pass down the runway where the mains just happen to meet the pavement... that eats up a lot of runway, seems that is more of a crutch than carrying power. Nor do I agree with the other method some teach of landing tail low then rocking forward, why not just three point?
I don't mean to criticize harshly or pretend I am a tailwheel expert, I like to try different methods and I have certainly been known to arrive rather abruptly at times
. Reading the techniques of others is what makes this a neat website!
David
