Which model is the plane for me?
All other things being equal (not very likely) the ragwing is 20 lbs heavier than all metal wing models due to it's necessary internal bracing.
I believe the factory "book" weight on all three models is 1,229 pounds. My ragwing weighs in at around 1,310 with full paint job,VFR panel & radios, 180 gear legs with Ponk kit, and single rear jump seat.
I think most if not all 170's are heavier than book weight. A friend had a bare-metal, stripped B model that weighed in at an honest 1,250, after a lot of thoughtful weight reduction.
The weight is gonna be all over the place for different airplanes, I don't believe that any one model will be consistantly lighter or heavier than another.
There's 3 ways to increase performance: better wing,more power, and lighter weight. The weight part is probably the cheapest way to improve things. Mine could stand to have about 25 more pounds trimmed off-- right above the pilot's seat!
George is right about the weight but to expand on "all things being equal" it is more likely to find a rag wing with minimal equipment thus lighter in weight than the "newer" models. Not to say you can't load a rag wing down with cool gadget stuff like a venturi vacuum system and maybe an extra radio or 3.
