Well, Dave (not Bruce...sorry) ...I'm not commenting on those statements about not being IFR rated ...but using a DG when flying thru clouds..... but....AR Dave wrote:Yep I'm glad I asked such a basic question. Thanks!
George I'm not legal for IFR. Flying to midfield and looking at the windsock is exactly what I've always done. .....
Bruce I do need to use that DG more as a navigational tool. Honestly I forget about it until I'm about to fly through the clouds. For that I set it to stay straight on course, if not I tend to turn right.
But picturing the runway layout and the direction I'm flying on the DG will work for me. I'll start practicing that locally and get in the habit.
Not being IFR rated does not mean you can't use IFR procedures and charts in VFR conditions. In fact, it would be good if all VFR pilots got familiar with them IMHO. YOu don't even have to buy the charts. (Although having a book of charts of the state or area you most commonly fly in the cockpit with you is always a good idea. I recommend the NOAA books because they all have a diagram of the airport on every page.)
Go to http://www.airnav.com/ and look up any airport. (Let's use Petit Jean for an example.) http://www.airnav.com/airport/KMPJ
If you'll look down on the page you'll see another link which will take you to an opportunity to download an Adobe PDF file of the NOAA approach chart for that airport runway. (Airports with multiple runways will offer you multiple approaches, all for free.) The following link will actuate when you click on that link. (Open it right now in a seperate window by right-clicking on the link below and select "open in new window".) http://204.108.4.16/d-tpp/0503/05795R3.PDF
Next you'll see the entire approach chart for an RNAV approach (the only approach available at Petit Jean). Look at the chart and you'll also see on the lower right-hand corner an airport diagram. The chart also lists ALL the airport frequencies in use, and it also gives a MSA (minimum safe altitude) should you get lost in the area (within 30 NM of the Initial Approach Fix (IAP) known as JETSI. (See those little quadrants drawn out with arcs and course-lines depicting the boundaries of the MSA areas? Normally a MSA is depicted from the IAF of approaches, and areas known as quadrants are depicted to show the MSA in that quadrant. Pretty handy in fog, heh? A MSA will keep you 1,000' above the highest thing in the quadrant, so if you get disoriented in that quadrant all you need to know to stay clear of all terrain/towers, bldgs/ etc. is climb to 3500.)
Now: Notice that the Final Approch Fix (FAF) for Rwy 3 is TOTCE. All you have to do is enter TOTCE in your GPS as a waypoint to fly to before proceeding to the airport KMPJ and when your GPS shows you at TOTCE all you have to do is turn toward the airport and there you are on 5 mile final!
Or, even tho' no approach is available for RWY 21, all you have to do is use the Missed Approach Point (MAP) UPAKE for your own VFR (home-made) FAF and use it to land on Rwy 21.
Now, ordinarily I'd discourage anyone from flying to an unfamiliar airport and entering a straight-in final approach because that negates the safety features of flying complete traffic patterns,...but to give you some navigational assistance toward a new field, you can fly to the FAF using the MSA, then turn toward the field, remaining at MSA or 1,000' above pattern altitude and that will give you an excellent view of the field, and an excellent opportunity to enter the traffic pattern from that point (either an upwind leg, or from over the field turning downwind.)
Hope all that verbage helped.
In any case, go get a NOAA book of approach charts for your state or area and keep it in the cockpit. It's a real helpful book to have, and you don't have to buy updates all the time, just update it once a year or so. In fact, find a local pilot who is ready to throw an expired book out (they are published every 56 days) and ask for his old one. They don't change all that much very frequently, and are certainly a good VFR tool to have.
Hope this is helpful.
