I’ve used an ordinary, automatic automobile charger rated at 10A for almost 45 years without any ill effects on lead/acid/flooded aircraft batteries.
(It’s Schumacher brand with an analog charge-rate indicator. While modern equivalents are still priced below $75, I’d avoid any from Harbor Freight or any off-brands if you’re shopping.)
With a new battery such as a Gill “pink power”, my charger will indicate 5A or slightly more for the first charge period during installation. It will taper-off to below 2A within 30 mins, and taper to 0 after a few hours.
It’s my personal opinion that the hoopla about aircraft batteries being so-different from common lead/acid auto batteries is not particularly significant. I also believe that the great-concerns promoted by some aircraft battery mfr’s suggesting that only very expensive and specific battery-chargers can be used with VRLA or “sealed” batteries is a cry of “wolf”.
Here’s why I feel that way: Our airplanes were designed with low-amperage DC-Generator charging systems controlled with vibrating-points regulators. These systems are no more sophisticated than 1950’s/early ‘60s automotive electrical systems using flooded-cell lead/acid batteries.
The batteries used and approved for these airplanes must be capable of being managed by those basic-technology electrical systems. All modern aircraft batteries …(lead acid, VRLA, etc) …Must be capable and Compatible with the existing aircraft electrical-system design …to be approved for installation in our Cessna 170’s utilizing the original charging systems.
If these “modern” aircraft batteries were Not compatible and properly served by the original, crude charging systems in our airplanes…. then they would Not be “approved” for installation.
I’ve used Gill flooded cell and Concorde VRLA batteries in my airplanes over 40 years without any difficulty. I also keep them on inexpensive automotive battery “maintainers” continuously…(not “trickle-chargers”) …when sitting in the hangar for the last 20 years, also without any difficulty. (about $21 at WalMart)
https://www.walmart.com/ip/EverStart-MA ... hEQAvD_BwE
My aircraft batteries typically last between 5 and 7 years between replacements.
(my comments reflect my own experience/opinion and should not be taken to be critical of the information others have offered)
