If you are buying an airplane and your goal is to start and continue flying it with a minimum of surprises, then get an IA who you trust, preferably the one who will perform annuals/maintenance for you in the future and inspect the airplane. To me the most important qualification for the person inspecting the airplane is his/her experience and knowledge of the type/make/model. Lets face it folks, these birds are 60 plus years old, and anyone who thinks they can get a "guarantee" out of any inspection is kidding themselves. Having said that, if you get a 170 "right", it is probably one of the most reliable and least maintenance intensive airplanes available.
If you decide to perform an annual for the pre buy, you are putting the seller in a precarious position because an IA performing an actual annual is required to enter the inspection in the aircraft maintenance records and notify the owner of discrepancies. Remember, the IA is responsible for the inspection. The owner is responsible for the airworthiness. Just like repair stations that inspect crank shafts, there are different "opinions" and "findings" from different IAs. I see and hear about that all the time. Frequently, honest and competent individuals have different standards and techniques. Who are we to say who is right or wrong?
The comment recommending an inspection with findings noted informally and provided to both seller and buyer is the best way to handle this IMO. This is not an inspection required by the FAA. The buyers IA should inspect. The owner should provide an IA or A&P to actually perform any "maintenance" required for the inspection and then return it to service on behalf of the owner. This avoids all the subsequent finger pointing and accusations (Oh that never happens in aviation, does it?). However you do it, make sure both seller and prospective buyer and mechanic all understand what is happening and who is responsible. An ideal situation would be if the airplane was due for an annual, in which case, both the seller and prospective buyer might benefit from an actual annual inspection by a mutually acceptable IA.
I am disappointed by pilots who would not trust an IA with maintenance records. That sends an intimidating message to the Aviation Maintenance Technician that is insulting and entirely unnecessary IMO. If you can't find a qualified IA who you can trust, you should consider taking up another hobby. If you can't trust him/her with your logbooks, do you mean to tell me you are comfortable putting your life and safety on the line when you go fly the airplane just inspected? Good grief!
Lets say you have an annual inspection and the IA makes a record of a condition you disagree with. That is not the end of the world. That IA is not required to correct that condition. You can take the airplane to another A&P, IA, or Repair Station and get it corrected/signed off. The most important thing is to get it done right. To be safe.
One last opinion, be careful buying an airplane a far way from home. You are at a total disadvantage. You are more likely to overlook an obvious major problem because of the stress you put yourself under on someone else's turf. Ask me how I know this
