BTW a correct rheostat for this application is not likely to be closed back as that one was. Your burnt up rheostat was probably to small which is why you found it in the condition you did. Your replacement will likely have an open element.
After we opened it and poked it, the insides sort of just crumbed to dust. A new one was only $35. I went with a 25W, 100 Ohm, open backed version that was recommended elsewhere on the forum. We'll see how that goes
bagarre wrote:How expensive is a new one?
I wonder if you could get that one re-wound.
But looks are not important. What is important is that the rheostat is sized correctly for the load in the circuit it is installed in. The number of and type of bulbs in the circuit determine the load. This is why you don't want to change bulbs, add or subtract bulbs willy nilly to this circuit.
That trip down the Hudson looks great and you could see where Sully put the plane.
John Hess
Past President 2018-2021 President 2016-2018, TIC170A Vice President 2014-2016, TIC170A Director 2005-2014, TIC170A N3833V Flying for Fun '67 XLH 900 Harley Sportster EAA Chapter 390 Pres since 2006 K3KNT
rusbac wrote:After we opened it and poked it, the insides sort of just crumbed to dust. A new one was only $35. I went with a 25W, 100 Ohm, open backed version that was recommended elsewhere on the forum. We'll see how that goes
Doubtful it will work well, Christine. I got one with those specs at first and it only acted as a switch, sort of.
