gahorn wrote:Aryana wrote:Here's a couple shots of the 1/16" ABS angle that will be glued on to address the corrugations.
Don't you think that may be over-the-top a bit as you consider weight?
Just thinkin'... perhaps paint might do just as well, since the imagination is being invoked anyway... ??
My background with modeling in precision aerobatics where weight really is the enemy. You'd be surprised how much we obsess over it even flying airplanes that have greater than 2:1 thrust to weight ratio. I switched out some servos in a wing panel of one of my F3A airplanes and saved 1.5 oz total in the airplane. Believe it or not, I could feel the weight difference, mostly with respect to the reduced rotational mass of the wing panel; even though the torque of the servo went down, the benefit of the lighter wing panel offset it. Lighter airplanes (in the style I fly, anyway) are always better off lighter as they are easier to fly in the wind and have more power on reserve.
That said, for a scale airplane, particularly one as this, you actually need and want weight. The airplane simply flies too light without some meat on the bones. Honestly, R/C J-3 Cubs really suck to fly because they have a ton of wing area and weigh the same as an airplane that is 1/3 the size. The long span throws off the vertical tail volume coefficient pretty bad and they only are somewhat fun to fly when there is no wind. One of the last projects I did for Horizon Hobby before I lost my job was a 1/5 scale Piper Pacer ARF for E-flite. I chose this for a couple of reasons...
1. I was never getting a 170 past anyone (I tried every day. For years)
2. The Pacer is a sporty looking airplane that's different from what people expect when they see a Piper modeled
3. The small wing area and short span that people don't like about the full-scale are exactly what a model needs to be happy.
I've got a 1/4 scale J3 that I'm clipping the wings on and putting in a 3 cyl radial engine to mimic the Lenape Papoose that was an option for those that had good luck with the Taylor Chummy and were looking to upgrade.
Anyway, keep up the great work, Arash! I just finished a little project myself- my first helicopter build. It's a JR Forza 450, nowhere near the level of detail and love you've put into your machine. I'm setting up the flybarless unit now and waiting on some batteries to come in so I can fly this bad boy.
