27% 170B build
- daedaluscan
Re: 27% 170B build
That looks so cool. I would have said not to bother, but the result is wonderful.
Charlie
1956 170B C-GDRG #27019
Re: 27% 170B build
The question that was running around in your mind no doubt was this. Do I drive the controls with servos which in turn drive the little Arash pilot or do I build a little animatronics Arash pilot to drive the controls?
This quandary would have kept me up all night.
Re: 27% 170B build
You'll need a servo or two in the litle Arash pilot to reach down and grab the flap handle, or are you going to install the EZFlap?
This is really an amazing thread. How long have you been off your meds?
- falco
Re: 27% 170B build
A four banger? I think that's your biggest deviation from stock so far. Now you need to do the cowling with the lycoming blisters to make it right with that engine...
- falco
Re: 27% 170B build
thats a cool looking motor. looks like a four stroke - what fuel,displacement, how fast do you run it? Is the propeller scale diameter? most important - will it sound cool?
Re: 27% 170B build
How will you set up the exhaust? Will you try to make 2 into 1's and come out in the original spots?
This is really coming along fast!
Re: 27% 170B build
I see a Behnam/Bartone mod in it's future.
- blueldr
Re: 27% 170B build
Arayana,
Simce you're installing a four banger engine, don't forget to put the two cheek bumps on the cowling.
Re: 27% 170B build
Bruce Fenstermacher wrote:The question that was running around in your mind no doubt was this. Do I drive the controls with servos which in turn drive the little Arash pilot or do I build a little animatronics Arash pilot to drive the controls?
Aryana wrote:EXACTLY! I found it easier (and less creepy) to go the servo route
WHAT!!?? You are going to MISS OUT on having a "MINI-ME"...???
- Ryan Smith
Re: 27% 170B build
They sound amazing. Very throaty, and surprisingly quiet. A friend has a Hostelter 150 with that engine and it's a hoot.falco wrote:...most important - will it sound cool?
I'm continually amazed at your craftsmanship, Arash. I love the movable yokes...very clever idea.
Re: 27% 170B build
I think you should bring it to convention and see what it'll bring at AUCTION!
- Ryan Smith
Re: 27% 170B build
Arash,
There are a ton of engine standoffs in the market, and I'd be willing to bet these places do custom work. I can dig around, if you'd like.
Re: 27% 170B build
In the first picture it doesn't look like you need stand offs just thrust wedges under the motor mount. Unless of course you don't want the look of thrust wedges.
Re: 27% 170B build
Wow that is parallax in action. I wondered why you moved the engine for, and the point of the second photo.
Those horizon hobby stand offs are cute. I'd make my own on my lathe today. What did I ever do when I built models and didn't have a lathe. Oh thats right I'd have used standoffs made of tube. What ever scrap tube I had around. Steel from car brake line or maybe vacuum system, aluminum or brass from K&B, copper from the ACE plumbing section. I'd look at the stainless brake line assortment as well. With steel brass and copper you can easily solder a washer to the ends for a flange. And don't discount hollowing out a wood dowel.
Re: 27% 170B build
I'm truly impressed by the amount of tribal knowledge being displayed by this group. It's humbling to see the amassed talents this membership encompasses.
