How long is your 170's airstrip?
Heflin
Post by Heflin »
I have landed and taken off from 1000' strips in the past. I just finished building a grass strip that's 1950' at 110' MSL. What do y'all fly off of?
ISAIAH 40:31
juredd1
Re: How long is your 170's airstrip?
Post by juredd1 »
I keep my plane at my Uncle's strip which Google Earth says is about 2130' long and around ranges from 1175' on one end and 1220' on the other. I also have a strip on my farm about 3 miles to the south that is 1600' long and ranges in elevation from 880' MSL on one end to 1000' MSL on the other. I use about 600' feet of both.
Justin
My playground....
35°58’52.01” N 93°06’27.51” W
'54 170B White and Green with a hint of Red
Freeway is 2400' at 168MSL and I rarely use more than 800 feet of it.
mike roe
Post by mike roe »
Its all in the approach. Clear approach, shorter runway. We are on 2000 with 60-70 foot trees on each end. It was a incentive to lose 20 lbs. A friend is on 1200 with clear approach and gets a 195 in and out.
Mike Roe
Ryan Smith
Post by Ryan Smith »
mike roe wrote:Its all in the approach. Clear approach, shorter runway. We are on 2000 with 60-70 foot trees on each end. It was a incentive to lose 20 lbs. A friend is on 1200 with clear approach and gets a 195 in and out.
Mike Roe
+1
W88 is 2460 at 822ft MSL. We takeoff downhill on 27 where there are no trees within 1/2 mile of the end of the runway. I almost put the 170 into some trees at Pace (VA02) a couple months back, which is a 3000ft strip with trees on each end. Hot, heavy, high density altitude.
Joe Moilanen
Post by Joe Moilanen »
My strip is 650' long with 600' useable. Did I mention the trees at one end? Elevation is 700'
falco
Post by falco »
2500' or 4800' or 5300' flat asphalt at 40' above sea level without significant obstructions. I get in and out of there just fine.
If I could change a few things it would be 1500' of sod up in the mountains somewhere. Perhaps someday.
moss farmer
Post by moss farmer »
Our strip is supposed to be 1800' but you have a road on approach. If it is 1500 I would be amazed. We do how ever have 4 170's based here.
Joe, that is a pretty landing strip you have there. It must result in LOTS of pucker factor :lol:
At first, I coudln't figure out what the big deal was. I thoguth the runway was the road thru town at the bottom of the hill 8O
The strip at the house in Alaska is 1400' with a 400' overrun at 385'msl. It has a clear approach on the north end and 60' trees on the south end with the overrun. I have flown out at gross weight on a standard day to the north with no problem. We have a lot of standard days there. I wouldn't try it to the south with more than two people and half gas. Landing has never been a problem either way. Any way I look at it the A model is a 1000' airplane.
Here's a couple of not-so-good pictures landing from the north at Hilltop Strip that was lifted from a video but you can get the idea of the trees on the "unobstructed" end of the runway.
Heflin
Post by Heflin »
Show me some pics of these strips y'all have! Mine looks like an international airport compared to Joe's. :lol:
Here's mine sporting a new growth of wheat. I started on it as soon as they harvested the soybeans in late September. It'll be next summer before I can start using it.
Running the land plane over it after a couple weeks of shaping and smoothing.
2.5" rain proved the crown was good. I pulled side ditches after this.
ISAIAH 40:31
Joe Moilanen
170C wrote:Joe, that is a pretty landing strip you have there. It must result in LOTS of pucker factor :lol:
It has lots of pucker factor! By myself with low fuel only for takeoff, unless it is really cold or I have a good headwind. Landing isn't tooo bad though.
Short grass, firm tire-pressures and thorough run-ups must be the rule, heh? :wink:
Joe Moilanen
gahorn wrote:Short grass, firm tire-pressures and thorough run-ups must be the rule, heh? :wink:
You got it!! :D
