Engine oil I am a new owner and shipping my aircraft to South Africa sortly, firstly I would like to get input with regards to what oil to use in my aircarft? The enviroment is similiar to LA, I have had a look and Shell aero W100 Plus looks good can anyone shead so light on what oil to use?
Inhibiting oil and procedure I would also like to find out what inhibiting oil to use and the procedure to follow?
Thanks folks!
What engine oil to use as well as inhibiting oil!
I recommend AeroShell W100 for operation in temperate or tropical climates, and W80 in cold climates (with the preferred proper engine pre-heating.) Without engine preheating I'd recommend their 15W50 multi-grade. The plain stuff. But NOT Plus! Plus has additives that contribute to degredation (leaching) of copper in bearings.
Shell producesan inhibiting/preservative oil called Shell Fluid 2F. It is available in 55 gal drums and 5 gallon pails. You might find some in suppliers stockshelves in the old 1-gallon sizes. Follow their recommendations and those of TCM.
Try their webpages:
http://www.shell.com/home/Framework?sit ... _page.html
http://www.tcmlink.com/
In answer to your question in the other discussion thread, I recommend the Champion 48108 spin on filter in conjuction with the FM Enterprises filter adaptor for the C145/O300 engines. http://www.fm-enterprises.com/
Try their webpages:
