Tailspring Stiffener bolt
Farnold
Post by Farnold »
8O Holy Cow!!
my tailspring stiffener U-bolt, part # 0510000-32 broke for my '52 170B.
I checked with Univair & another source and that little part is $139.00. Now this is absurb! Anyone know of other sources are alternatives as it is really just a u-bolt that is threaded at both ends.
I don't think I can just use 2 straight bolts and 2 plates as the bottom of the tailwheel bracket assembly has 2 rivets that protrude out and I don't think a bottom plate would fit well. At least the locking nuts are only about 20cents each.
Alternatives would be appreciated
jatkins
Tailwheel U bolt
Post by jatkins »
Hi,
I recently got a new tail wheel U bolt from Air repair .
http://www.airrepairinc.com. I do not recall the price but
was not ant where nr=ear that price !!
N2255D
Post by N2255D »
I had one manufactured at the machine shop for $50.00 after finding out how much they cost.
Farnold
tailspring stiffener bolt
Post by Farnold »
I tried to look up the part # earlier on Air Repair and could not find it. Could they have a different # for it then Cessna/Univair?
BTW Univair's price is about 20% higher than others. All are outlandish!
I was fortunate as when I spotted the sheared off bolt/nut, I jacked up the tail and found the Scott T/W to be very loose at the bolt that attaches the T/W to the springs. I could hand remove the nut from the bolt!
A slight disaster was truly avoided. Not sure what I did to do this however. I'll now check the T/W - spring bolt with each pre-flight. I now have a pair of wrenches placed out so I will not have any excuse and won't have to rummage around for the proper wrenches.
Air Repair specializes in L-19 parts, many of which are identical to 170 parts except for the part number. It's best to just call them on the phone, talk to Pete and let him know what you want. He usually knows the corresponding part. While you're at it, replace that tailwheel attach bolt (AN7-20A) with the eye-bolt that L-19's use (PN 0642105). Makes it a lot easier to tie-down the tail, and it replaces your already stressed bolt with a new one.
3993v
Post by 3993v »
In july of 03 I bought a u-bolt from jta aircraft for 15.00 bucks. There part number is 0642133. They also have the tailwheel attatch eye bolt new old stock for birddogs for 21.00 at that time. That part number is 0642105. http://www.jtaco.com phone 970-221-4230 nick
Farnold
Post by Farnold »
Thanks for the great tips everyone. I tried AirRepair whom I obtained the eyebolt replacement to ease t/w tiedowns. Replacing that is what started this whole thing. They are shipping one out for $32 or so if I remember correctly. I called them before I saw the tips about jtaco.com.
Re: tailspring stiffener bolt
Farnold wrote:I tried to look up the part # earlier on Air Repair and could not find it. Could they have a different # for it then Cessna/Univair?
My 1948 IPC shows a self-locking nut at this location. I'm not sure,but I might even have a castelated nut & cotter key on mine. Either way,it shouldn't come loose. Maybe you need a new nut.
Blue4
Re: Tailspring Stiffener bolt
Post by Blue4 »
Revive of an old thread to update some information. I needed a U bolt as others did years ago. As of today, for about $58, Air Repair has the L-19 cross of 170B part# 0510000-32, U bolt. The part number is 0642133 in L-19 language. Thanks to Air Repair in Mississippi!
Once again: 0510000-32 = 0642133
redacted
Post by redacted »
Thread update. Air Repair has them, $58.50
Nathaniel Perlman
1952 170B
N2282D S/N 20434
mit
Post by mit »
$139 sounds cheap.
