40-75D vs 40-97A wheels
Can any one tell me the difference between these two wheels? Both are 6.00 x 6 with a static rating of 2500 lbs. The data tags show a .7 lb difference in weight (97A is lighter). Are there physical differences that would preclude installing either interterchangably?
- lowNslow
Re: 40-75D vs 40-97A wheels
The 40-97A wheels are the ones STCed for the 170, the 40-75D are for Cessna 180 - 210 aircraft. The Parker catalog mentions that the 40-75D "may not work with wheel pants due to the wider offset of brake disc".
https://www.parker.com/literature/Aircr ... PC0001.pdf
- n2582d
If you compare the wheels in the link Karl provided you'll find that all the parts are identical except that the 40-75D (the C-180 wheel) uses brake disc 164-03601 whereas 40-97A (the C-170 STC'ed wheel) uses brake disc 164-02601. This explains the weight difference as the 164-03601 has a minimum thickness of 0.327" vs. the 164-02601 which has a minimum thickness of 0.205" The C-180 disc uses a dual piston brake assembly p/n 30-52N whereas the C-170 disc is mated to the single piston brake assembly p/n 30-63A. The only other difference I noted was that the 40-75D assembly comes with a "dust shield" -- what I would call a hub cap, p/n 157-00900. So if you found a good deal on 40-75D wheels and wanted to interchange them with your corroded 40-97A wheels you could do it as long as you kept your 30-63A brake assembly and 164-02601 disc (or 164-12601 chrome disc). But the logbook entry should read something to the effect of "replaced inner wheel half assemblies p/n 161-03000 and outer wheel half assemblies p/n 162-02700 removed from aircraft xyz ..." rather than "installed wheel assembly 40-75D ..." as the 40-75D assembly includes the thicker disc which is not approved with the 40-97A assembly STC.
Thanks guys. I appreciate it. Happy Thanksgiving.
