180 Lycoming STC
Bruce74C
180 Lycoming STC
Post by Bruce74C »
Who currently holds and is still in business to suppply the STC for a 180hp Lycoming conversion? Does anyone have current contact information for the STC holder(s)?
Thanks,
Bruce
Harry Dellicker/DelAir
2121 So. Wildcat Way
Porterville,CA 93257
559-784-9440
Don't have an email address or website for DelAir.
There have been other STC's over the years--Avcon/Bush,Doyn,Turner,KWAD,RFB-- for installing the Lycoming O-320,O-340,O-360,IO-360,and even the O-435,but I don't know how many of them (if any) are being marketed these days.
A Lycoming conversion ain't cheap,but I guess it makes a "real airplane" out of the 170,as does the Cont IO-360 or the 220 Franklin. As any old hot-rodder or biker knows, there's no substitute for cubic inches!
ohanley
Post by ohanley »
Remember the Pontic 4 banger's Micky Thompson played with?
Back in the 60's Micky Thompson proved there was a substitute for cubic inches.........."CUBIC MONEY"!
I don't think there is an airplane or boat owner who isn't aware of the law of "cubic money".
:lol: :lol: :lol:
ohanley
N5756C
Dave Clark
Post by Dave Clark »
Bruce
If I were to convert with a new kit today I would go with DelAir because he has a 200lb Gross Weight increase STC FOR HIS CONVERSION ONLY.
Mine is the older Avcon conversion out of Udall, KS. Buyer beware if you deal with these people.
N92CP ("Clark's Plane")
1953 C-180
I was just looking at the Q1/2004 170 News,and noticed that DelAir has an ad in the back. I believe Dellicker is an Assn member.
Ditto Dave's comments re: Avcon/Bush Conversions/Bob & Barbara Williams of Udall Kansas. I don't know of anyone who has had satisfactory dealings with this outfit.
Maineboy
Post by Maineboy »
I have read this conversion can cost over 30k. Does anyone have a breakdown of money spent on a conversion. Just wondering how much of this is labor, engine cost, prop, accesories etc,. How many hours it takes to convert one?
I fly mostly floats and skis and could use the bigger engine.
Brian
'56 170B N3532D
Dave Clark
Here's a guess:
STC with mount cowl mod and other parts $6000
Engine field OH outright $15000
Prop and spinner $7500
Misc Governor,vac pump, instruments, etc $3000
Labor depends on how much you can do yourself. I would think that if you had it all done you could sell your old FWF to cover it.
I now have a net of $20k in mine with a fresh engine but I got some good deals and did all the work myself.
Call Harry Dellicker, he's a kick to talk to.
1953 C-180
Maineboy
Post by Maineboy »
Thanks for the information, do you have a rough estimate on the hours it takes to complete the job? Thanks
It's kind of a toss up, sell mine and put money with it and buy a C-180 or spend 20-30k on a conversion. Probably in the long run it would be less expensive to keep the 170.
Brian
'56 170B N3532D
Bruce74C
Post by Bruce74C »
I have made some phone calls to the STC holders and the cost of conversion looks like this:
STC with all bits and pieces: $9,200
Prop & governor: $9,000 (new)
Engine: $26,000 (New Lycoming)
Total: $44,200
The Continental IO-360 is the same overall cost.
Of course finding a used / OH engine and prop is the key to keeping the costs down. Installing a fixed pitch prop helps also.
If I sell my 170A and add $44,000 to the proceeds I still cannot buy a C-180 in as good condition as my 170A. The added operating costs of a C-180 are an issue also. If the STC holders get the 250-300 lb. gross weight increase for the 170 then a souped up 170 will pretty much match a C-180.
Let's hope my engine stays together while I save my pennies.
Bruce
A fixed pitch prop negates a lot of the advantages of more hp. :?
A O360 Lycoming doesn't make 180 hp unless it's running at max rpm.
Why spend $35 grand for only a few more hp?
The C145/O300 only makes about 120 hp at takeoff due to the fixed prop.
A variable pitch/constant speed on this C145/O300 would make it a new animal!
I guess what I'm saying is that I don't think I could get excited about a 180 Lyc without a constant speed. If I were to favor a fixed pitch prop, I'd probably lean more toward a (potentially 210 hp) Continental IO-360/O-360 with one. (Fords/Chevy's, etc.)
dkalwishky
Post by dkalwishky »
I have been thinking about upgrading my '56 C172 to 180hp via Harry's STC. Here is a message I posted recently on the Cessna Owner's Organization website.
What a coincedence. I spoke to Harry at Del-Air a few days ago about this very thing. He has two STC's, one for a fixed pitch prop ($8700) and one for a Constand Speed prop ($9200). Trade-A-Plane has Lycoming O-360-A4M engine for 13.8K to 16.8K but you will need a mechanic to install it, not sure how much that will run. A 172 is a pretty simple plane so lets say 40 hours (which is one week) at $55 per hour is $2200. All that adds up to $28.2K at the high end of the numbers I have listed. Now it may take more than a week to do the swap, I have no idea how long it will take.
dkalwishky
After rereading my post I realzie that I have NOT included a prop. Thats a pretty important piece :oops:
Dave Clark
George wrote:
"A fixed pitch prop negates a lot of the advantages of more hp.
A O360 Lycoming doesn't make 180 hp unless it's running at max rpm...(snip)...I guess what I'm saying is that I don't think I could get excited about a 180 Lyc without a constant speed."
Generally I agree wholeheartedly, however, an exception might be a plane on floats full time with a long seaplane prop set to hit the 2700 static. It'll never get much airspeed in cruise anyway.
I like the Lycoming but then you can't have too much power so it would be fun to try the IO-360 with the constant speed. I guess then I'd have a true XP huh?
1953 C-180
AND you'd have a smooth-runnin' six-cylinder instead of a 4-banger.
And then there's the 220 Franklin conversion (Of course the Franklin & the Continental can't burn car gas. George,that'd kill the deal for you,I know how much you love that stuff.)
And then there's the O-470 conversion,otherwise known as the Cessna 180. And for that there's the Ponk +50 (O-520) conversion. And then there's the IO-520 conversion,also known as the Cessna 185. Then there's the IO-550 conversion,and the IO-540 conversion........Just goes on & on.
IMHO,the Lycoming O-360 seems the perfect match to the 170 airframe,all things-- cargas compatability,fuel burn,price,horsepower,size,availability,track record,etc-- considered. Or maybe the IO-360 Lycoming if you need a smidge more steam.
