Nose Bowl Replacement
Posted: Sun Jan 03, 2021 10:18 pm
by Poncho73
I finally started on repairing my 48 cowl. I’m currently concentrating on the nose bowl. Today I removed the nose bowl and subsequently discovered I need left and right angle rub strips p/n 0552000-9 and -10. Does anyone have a lead on where to get them. The originals were spot welded in place, my strips are not salvageable.
Re: Nose Bowl Replacement
Posted: Mon Jan 04, 2021 12:26 am
You are very likely going to find it easier/simpler to make them yourself.... but Textron (Cessna) and AeroVal claim to have them available...IF you request a “quote”. Good luck with that.
Posted: Mon Jan 04, 2021 12:55 am
by Poncho73
GAHorn wrote:You are very likely going to find it easier/simpler to make them yourself.... but Textron (Cessna) and AeroVal claim to have them available...IF you request a “quote”. Good luck with that.
Kind of expected that response...... anyone have a pre 52 lower cowl?
Posted: Mon Jan 04, 2021 2:32 am
by c170b53
I see curved wooden blocks in your future....or Univair if you scratch and win big :D
Posted: Thu Jan 07, 2021 5:36 pm
by Poncho73
I finished the angles today. Yes wood former and plenty of hammering
Posted: Fri Jan 08, 2021 5:17 am
by DaveF
Pics! Pics!
Posted: Sat Jan 09, 2021 11:30 pm
by Poncho73
Angle install pics
Posted: Sat Jan 09, 2021 11:35 pm
by Poncho73
Moving along today I riveted the bowl to the main lower cowl skin. I will post the pics tomorrow. I was so busy I didn’t take pics today. Here are some of the pre-riveting cowl
Posted: Sat Jan 09, 2021 11:41 pm
by Poncho73
Pic of the original bowl. After 73 years there have been numerous repairs
Posted: Sun Jan 10, 2021 12:02 am
by Poncho73
So tomorrow’s plan is to paint strip the grill vents and install then. Then install the winter front doubler and anchor nuts. Then continue work on the air inlet.....I have some mods that I’m considering.....certified of course. Also, every cowl screw fastener, previously tinnermans will be replaced with floating 10/32 anchor nuts and SS screws. Plenty of work but a worthy enhancement.
Posted: Sun Jan 10, 2021 1:36 am
by c170b53
Nice work on the cowl. Thanks for the pics.
Posted: Sun Jan 10, 2021 5:10 pm
by DaveF
Great-looking work! Thanks for the pics.
Is that a replacement Cessna nosebowl or did you make it yourself?
Posted: Mon Jan 11, 2021 12:24 am
by Poncho73
The new nose bowl is an NOS part. Keep in mind it is only a shell. There are no doublers/frames/stiffeners. You need to build them, or salvage from the old nose bowl. My nose bowl was beyond repair or salvage so I had to get creative and manufactured the frames. Moving forward, today I completed stripping the the grills and prepping them for install. A rivet squeezer is the best tool for this job. I also reinstalled the anchor nuts for the winter fronts. Couple of pics from today...the cowl is framed up and fits well. Tomorrow I’m working on the intake. As I said I have a plan for something new rather then the original cumbersome air scoop. Cheers all
Posted: Sat Jan 23, 2021 10:19 pm
by Poncho73
Air scoop arrived. Sheet metal work coming up, plenty of cutting and fitting, rivet tomorrow
54320E93-C3FF-4B01-A42A-5CE092DF470A.jpeg. [attachment=1]54320E93-C3FF-4B01-A42A-5CE092DF470A.jpeg
Posted: Sun Jan 24, 2021 1:23 am
by c170b53
Carbon fibre ? My aluminum has a few cracks, stop drilled but unsightly, might have to go that route.
