Early Baffle Seal
Early Baffle Seal
I'm looking to replace the black baffle seal which is found on the '52 and earlier bafflng. This is the black material that looks like its come kind of covering rolled over a round rubber filler and stitched.
I'm sure Spruce or Wag Aero sells it but it's difficult looking at the cateloge pictures determining what is the right stuff.
What has anyone else used.
doug8082a
Post by doug8082a »
I was able to order this through YingLing using the old part number from the IPC (sorry, don't have mine in front of me right now). The kicker was the price... $12.50 per foot 8O
It's a heavy duty cowling seal constructed of buna-n cover sewn around a 1/2" silicone cord. It has a 1/2" bulb with a 1" flap on it. I can get it in 9 ft lengths for $10/ft which includes a $5 donation to TIC170A.
My email address is on the cover of each Flypaper, or you can PM me, if you want it.
Jims170A
Re: Early Baffle Seal
Post by Jims170A »
"I'm sure Spruce or Wag Aero sells it but it's difficult looking at the cateloge pictures determining what is the right stuff.
What has anyone else used."
I bought some from Wag Aero. Item # I940000 Cowl Seal 9 FT roll (VS-6491) shown on page 25 of the new March Sun' n Fun Issue I just got in the mail. Lists for $58 plus about $10 to ship.
Wag Aero lists this as a CODE 8 Item, which means it does not carry an FAA/PMA, TSO and is sold for Experimental aircraft use.
I needed a short piece (less than 2 feet) along the top of the back of the inner cylinder cowling. I found it was a little fat and did not fit that well as it was difficult to close the inner cowling with the seal in between the two. The flange is only about 3/4" wide.
I have over 7 feet left of this, if it's something you might be able to use, I'ld be happy to mail you a chunk of it to try out.
Jim
Jims170A@cs.com
