Brake Pedal Spring
Posted: Sat Jan 16, 2021 6:20 am
by reecewallace
My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
Is the spring broken or does it not exist in the first place?
Re: Brake Pedal Spring
Posted: Sat Jan 16, 2021 1:00 pm
It is broken. Both pedals have a spring. The spring does not really return the pedal to neutral but keeps tension on the cable. A spring on each more or less balances each other out, another reason the pedals won't really center with 2 good springs.
Posted: Sat Jan 16, 2021 2:16 pm
reecewallace wrote:My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
You should obtain an Illustrated Parts Catalog (IPC) for your airplane if you’re going to work on it. It’s simply a MUST HAVE.
Posted: Sat Jan 16, 2021 6:19 pm
by reecewallace
GAHorn wrote:reecewallace wrote:My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
I downloaded the Cessna 170 parts catalog (255 pages long). It's from 1956. This the right one?
Posted: Sat Jan 16, 2021 7:17 pm
reecewallace wrote:GAHorn wrote:reecewallace wrote:My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
If you have a B-model...Yes.
A glance at the pages 101 and 101A would have answered your question on rudder return springs.
Posted: Sat Jan 16, 2021 11:41 pm
by DaveF
Search the forum for info on rudder return springs. There are a few tips on how to make the replacement job easier.
Posted: Mon Jan 18, 2021 6:16 am
by reecewallace
The Rudder Return Springs part #s are 0310196-3 right and 0310196-4 left respectively from the 170 catalog. However, can't find em on Aircraft Spruce Canada.
Any other reputable sites which ship to Canada?
Posted: Mon Jan 18, 2021 8:12 am
reecewallace wrote:The Rudder Return Springs part #s are 0310196-3 right and 0310196-4 left respectively from the 170 catalog. However, can't find em on Aircraft Spruce Canada.
Although Spruce sells some common Cessna parts, they are not a source for most factory parts.
I Suggest you seek them from a Cessna distributor. They used to be some of the most reasonably priced parts Cessna sold, but now they are about $32-$43 each:
https://www.cessnaparts.com/?s1=0310196 ... arch+Parts
Posted: Sun Jun 06, 2021 8:25 pm
by hartisja
Re: Rudder return springs
I have a 48 170 model
My parts catalog on page 95 shows the springs, but does not call out the part numbers.
Are the part numbers referenced above good for my model (0310196-3/4), or are they different?
Posted: Mon Jun 07, 2021 1:14 am
by sfarringer
Yes.
Figure 22, Reg No. 6, page 43
Posted: Mon Jun 07, 2021 1:25 am
by mit
Putting these on is easiest if you shrink your hands first!
Posted: Mon Jun 07, 2021 12:01 pm
by dstates
