850-6 4ply aero classics
Worm Jenkins
Post by Worm Jenkins »
I bought the 8.50-6 4 ply for the 170 and I am familiar with the ACO letter to Altee dodge ,it says a 337 and weight and Bal entry , are they sayin the letter constitutes approved data and does not need field approval or is it just acceptable and still needs to be bought off with field stamp ?
wabuchanan
Re: 850-6 4ply aero classics
Post by wabuchanan »
The letter is the basis for your IA to sign off the 337, and you need a current W&B with the new tires. That is what I did several years ago. There are other threads on here discussing the basis for the letter.
1950 170A N5776C SN:19730
Worm Jenkins
Yes I understand that I am an I/A but that letter seems to be acceptable not approved data and that was the question on the interpretation of it ,
Worm Jenkins
I perused the atlee dodge letter And the previous letter that the aco referred to and the anchorage fsdo agreed this item requires field approval and the letter is not approved data but substantiates acceptable data .
mmcmillan2
Post by mmcmillan2 »
I’d like to know as well.
The ghost of bluElder appeared in a dream last night and asked “Isn’t it a minor alteration to take a wire-wheel and grind the tire-size legend off the sidewalls?” :lol:
Worm Jenkins
Here is the response from aco anchorage
Subject: RE: Tires
Hi Mark,
The letter that sent to F. Atlee Dodge Aircraft Services reiterated that the policy that was stated in the 1961 Flight Standards letter had not been rescinded and the policy could be used for modern field approvals. Also at the time Flight Standards was working on an advisory circular that also said the same thing. It is not my call on what constitutes “approved” data for a 337. However, the 1961 Flight Standards Letter is reiterated in paragraph 2 of my letter. There is no technical concern with what is identified in Paragraph 2. So did I do a good enough job avoiding the question but still give you enough to work with? If not please ask more we have a lot of experience with tire changes like this and I am happy to help you find a good solution.
August
August A. Asay, Manager
Anchorage Aircraft Certification Office Branch, AIR-770
Compliance and Airworthiness Division
Aircraft Certification Service
(907) 271-2673, fax (907) 271-6365
Worm Jenkins
Is there anyone that has field approval for this installation?
