Is this an over-voltage device?
Posted: Mon Mar 01, 2021 1:14 am
by Larry E
I'm hoping someone might be able to identify what this unit is:
The main positive output wire from the alternator goes to the left side terminal; and the right terminal wire then goes to the ammeter and main bus.
There is no identification on it - anywhere!
The aircraft came to Canada in 1974 and we don't have the American logs. There's no mention in the Canadian logs of the change from a generator.
Perhaps someone who's been around these old Cessnas for many years might remember seeing something like this.
Here is the voltage regulator;
If it is an over-voltage device, does anyone know how they work?
Thanks in advance,
Larry
Re: Is this an over-voltage device?
Posted: Mon Mar 01, 2021 3:02 am
by n2582d
Larry,
That's a Radio Frequency Interference (RFI) filter. Here's one from Aircraft Spruce.
by c170b53
A quick glance, I would say thats a noise suppressor, removing any noise on the line.
Posted: Mon Mar 01, 2021 3:16 am
by c170b53
Now I’m looking at the hole in my cowboy hat like Timothy Blake Nelson, in The Ballad of Buster Scruggs. You got the draw on me Gary!
Posted: Mon Mar 01, 2021 4:08 am
by Larry E
Gary and Jim
Thank youse!
I've not seen these before - are they needed? Or is it possible they were used as a band-aid to cover poor grounds, unshielded plugs and harness's or unwise cable routing, etc.?
There are also 2 magneto filters installed - one on each P-lead exiting the mags.
I'm wondering if all this was done in the 1960's, and perhaps not needed with modern avionics??
Larry
Posted: Mon Mar 01, 2021 6:12 am
by c170b53
I rewired and installed one in my power feed years ago. Might be overkill or cheap insurance, I guess its up to the beholder.
