Soft Brake Pedal
Posted: Wed Jun 28, 2023 3:02 pm
Why the left brake pedal required “pumping” to build brake pressure:
NOT the Master Cylinder, which was rebuilt thinking it had a defective “Lok-O-Seal”.
NOT the hydraulic lines leaking.
NOT the flexible line to the caliper, which had been replaced because it was old, stiff, and applied a “twist” to the caliper that appeared to move the linings away from the disc between brake applications.
Nor the brake linings themselves which are new.
But THIS…. which moved the linings away from the disc between brake applications…and therefore required multiple applications of pedal-pumping to gain any braking action. (Click on the pic to set the video in-action): https://photos.app.goo.gl/hHQeBDWfusi38aMGA
(This was first noticed while spinning the wheel on the airplane…After discovering that while looking down from above the wheel…”light” could be seen between the linings and the disc. Normally linings remain in-contact with the disc between brake applications…they just aren’t applying pressure until the pedal is applied.)
Both brake discs are being replaced since these old ones are at minimum thickness (0.20”)
