L-19 Bird Dog Bulkhead Part Numbers the same?
Does anyone have a copy of the L-19 parts catalog for the tail section? I'm in need of the part numbers for the last two aft bulkheads to determine if they're common to the 170B tail section but have had no luck finding a catalog
Re: L-19 Bird Dog Bulkhead Part Numbers the same?
While many L19 part no’s have similar digits….(for example a 170B PN 0511XXXX while the L19 PN 0611XXXX might be identical part)….this is not always true. So you cannot rely solely upon the PN to determine compatibility.
I suggest you contact Air Repair in Cleveland, MS to resolve this issue. They are quite familiar with the interchangeability of parts. 662-846-0228
I doubt the L19 will help you, but here are two screen shots of the affected pages: (Click on them to Enlarge them)
