What is the part # for the C145-2 crank seal. The number listed in spruce is the same as the C85 taper shaft seal. That doesn't sound right.
Crankshaft Seal
- mit
Re: Crankshaft Seal
figure 4 item 19 listed as no number then it shows 530974. felt seal 539242. Might be 539241 that is seal and felt assy. I bet that didn't help did it?????N73087 wrote:What is the part # for the C145-2 crank seal. The number listed in spruce is the same as the C85 taper shaft seal. That doesn't sound right.
