Carb heat control for 170B
Posted: Sat May 07, 2005 11:54 pm
by N170BP
Pulled the carb heat out abeam the numbers today upon arrival
at my home base, and the darned thing came out in my hand 8O
(the white knob with about a 4 inch section).
I dug through the parts book, and it says the following:
Figure 42-13
Page 75
For serial 25373 - 26038
P/N = 0411090-12
Figure 42A-13
Page 75A
For serial 26039 - 26995
P/N = 0411090-8
My serial # is between 26039 and 26995, however, the panel in
my airplane looks like figure 42, not figure 42A. Is the parts book
in error here?
Premier has a 0411090-22 (supercedes the dash eight) for $61.28.
Is the only difference in the dash numbers the overall length?
I also had a look at McFarlands web site, and near as I can tell,
S1230-17 is the control I want (says it's PMA'd for all single
engine Cessnas).
Has anybody ordered either of these before for a B model?
Posted: Sun May 08, 2005 2:43 am
by johneeb
Bela,
In order to retain the original knobs on my panel I have twice had success cutting off the old wire at the shaft end drilling out the end and silver soldering a new wire into the end of the shaft. I got the new wire from a cable that I found at the aviation department of the local NAPA store. :wink:
Johneb
Posted: Sun May 08, 2005 5:35 am
by zero.one.victor
Bela, I think maybe I'd check out the generic cables in the Spruce catalog. You should be able to find something suitable for a lot less than sixty-one bucks. I just took a quick look & saw a few possibles listing at as low as $14. All you need is the inner wire part, but I don't see anything except complete assemblies (inner wire & housing). You could always pull the cable out from the new assembly & slide it into your existing cable housing, and cut to length as required. The one I'm looking at (p/n 05-13672) is .050" wire and 6 feet long, and lists at $22.70 for the complete assembly. They also show some .078" wire control cables.
Posted: Sun May 08, 2005 3:51 pm
by Metal Master
Hello Bela,
I just purchase a carb heat cable a couple of weeks ago from Cessna for a Cessna 182B through Galvin's of all places. I was surprised that the part was only $33.97 my cost.
I was also surprised that when it came it had a white knob. The cable was generic in that it was about three feet longer than I needed it.
Part number 0713302-5
It was nice to meet you and see your 170 Out at Tom Jensen’s a few weeks ago. I just finished manufacturing the rudder cables the center and forward floor panels for my 170A. If I can get some time I will get all of the cables and pulleys installed and then install the panels.
Regards,
Jim
Posted: Mon May 09, 2005 1:15 am
by N170BP
Thanks for the ideas everyone.
I ended up ordering the S1230-17 control from McFarland,
but I like the idea of getting a white knob (original looking)
instead of the replacement black knob that comes with
the McFarland unit.
I have to go up to KBFI anyway to go to the instrument shop,
so I'll swing by Galvins and have a look at that 0713302-5
182 carb heat control as well.
