Fuel selector - packing replacement
Posted: Thu May 19, 2005 2:26 pm
I searched the forums and found the thread about replacing the packing in the original brass fuel selector for ragwing models. Even the replacement part # for the original packing is no longer available, and the only guidance from Cessna is to replace the entire assembly. That is overkill. Can anyone suggest equivalent packing material that will work in the original fuel selector valve assembly? And if the valve must be replaced, does anyone have field approval experience as it will be well off the original type certificate.
Thank you -
Richard
Thank you -
Richard
