Bendix S6LN 21 mag impulse problem
Posted: Sun Aug 07, 2005 7:12 pm
Just finished my annual and while doing the compression check we noticed on impulse coupling was not working on every other firing in one mag. We would heard and feel two clicks then one.
If we turned the prop at a reasonable rate it would not work. Later we discovered if we turned the prop real slow as is creeping both would fire most of the time.
We have pulled both mags which have 570 hours since remanufacture and 97 hours since the last impulse AD inspection.
With a visual inspection only the all the fly weights l look to be in excellent shape and working properly. We will inspect the mags per the AD and reinstall them.
Here is my questions. With the mags timed properly as they where and with 2 distinct clicks on one firing is if possible that both impulse couplings could fire so close together as to seem as one on the next firing? I don't think so. Or has anyone come across this scenario before when it seemed as though one impulse was not working every other time?
We're just trying to understand what's taking place.
