RIGGING
Posted: Tue Jul 30, 2002 9:09 pm
by bertibub
HELP!!!
We are rebuilding a 150 C170A ser no19674 prev HB -CAZ now N170 AZ. Rigging the controls and flaps is a problem. The right and left flap fairings do not match and as these are the reference points for the flap which then is used for the ailerons...
The log books state that in an accident in 1955 the left wing was replaced with a second hand one....Are there any other ways of setting the rigging in the plane?? How can one tell that the wings are both from a 170A and not one from a 170B?
Cheers afrom Scotland
Bert
Posted: Wed Jul 31, 2002 10:37 am
The flaps are totaly different from the A to B model with the B model being bigger like found on a 172 today. How is it that the fairings don't match?
Re: RIGGING
Posted: Wed Jul 31, 2002 7:44 pm
bertibub wrote:HELP!!!
Bert
What do you mean by "fairings do not match"? Do you mean that the wing-root fairing on the fuselage left, is not identical to (mirror image) to that on the right side of the fuselage? Or do you mean they do not match up to the wing root at the flap?
Rigging
Posted: Thu Aug 01, 2002 6:54 am
by bertibub
George both! The fairings look similar but they do not sit the same in terms of height at their outside outboard edge so they then do not allow the flap inboard edge to line up the same on both sides at the same time. We can match one or other up but not both.
Bert
wing root fillet
Posted: Sat Aug 03, 2002 12:30 am
by n2582d
Bert,
How much higher is one side than the other? On my C-170B the trailing edge of the right side fillet is 472 mm above the top of the side fuselage aluminum panel and 468 mm on the left side. In looking at the parts catalog I see that the part number for the fillets is different between the A and the B model so these measurements probably don't correspond on your plane. Maybe someone with an A model could give you this measurement on their plane for comparison to yours.
I would recommend using a digital inclinometer like the "Smart Tool" available from Aircraft Spuce
http://www.aircraftspruce.com to rig your controls. Cessna Pilot's Association has a good article on rigging in their Tech Note #14.
What's with the "N" number in Scotland? Where do you find a U.S. I.A. to annual your plane?
Rigging problems
Posted: Sat Aug 03, 2002 5:54 am
by Dr. Dave
would it be possable for you to locate and print a copy of the cessna Pilots assoc. article 14 for us??
I am facing some rigging problems and would like that information to add to what i have now..
Thanks..
Rigging info
Posted: Sun Aug 04, 2002 12:57 am
by n2582d
Dave,
The 16 page "tech note #14" is copyrighted. In addition to the article on rigging I've found CPA has a lot of other useful information as I rebuild my C-170B. Especially informative is their 172 forum where members with older 172s discuss issues related to their O-300. Another forum discusses modifications-- STOL kits, vortex generators, and shoulder harnesses to name a few. Contrary to the opinon of some others on this site I've found joining CPA worth the money.
http://www.cessna.org. For other I.A.s out there they have seminars (even one dedicated to rigging Cessnas) which will qualify for your annual renewal.
RIGGING
Posted: Sun Aug 04, 2002 9:49 pm
by bertibub
Gary,Rebuilding a 1950 170A was easier on the US Reg than on the British Reg you don't want to know what the space cadets at the CAA (Campaign Against Aviation ) get up to here. Thge aircraft is held by a US trust with myself being the sole beneficiary. Quite a common setup here. There is one IA and two A&Ps here in Scotland that i know of.
Anyway guys no one has come up with an answer to the original question...Any Help out there?
Bert (presently grounded!)
Rigging
Posted: Mon Aug 26, 2002 7:20 pm
by hallwerks
The flaps may not line up with the root fairings because of the adjustment of the the rear spar cams. Exact alignment is generally not possible The flap are aligned to bottom contour of the wing. The up positions is controlled by the two stop bolts mounted in the rear spar. The flaps may or may not line up with the with the root faings.(see first sentence) The down position is controlled by the flap cable adjustment turnbuckle located at the rear of the baggage compartment. The maximum down position is 50 degrees of travel, be sure to measure and adjust both flaps. Reference the 170A POH, page 40. If you are rebuilding this aircraft I suggest that you do a complete rigging procedure starting wih a symetry check. If you have further questions write me at <
wkpt13a@earthlink.net>.
