Chief aircraft has them. They are shown for a David Clark headset, but they are just the generic little "foam bags" with a draw string. Should work on most mics. http://www.chiefaircraft.com/airsec/Air ... ories.html
I should have a macro for my keyboard for all the times I tell folks to check out Aircraft Spruce. http://www.aircraftspruce.com/
877-477-7823
They probably have a newer catalog out now, but my copy has 6 different foam mic-muffs listed on page 481 priced from $2.95 to $13 that apply to every brand/model headset out there.
A whole bunch of the pilots that I work with buy foam hair rollers and cut them shorter. The small diameter ones that are about three inches long come in both baby blue and pink and a pack of 25 costs 2 or 3 bucks. A couple of whacks with the scissors and you'll have more foam thingies than you can ever eat.
KG wrote:A whole bunch of the pilots that I work with buy foam hair rollers and cut them shorter. The small diameter ones that are about three inches long come in both baby blue and pink and a pack of 25 costs 2 or 3 bucks. A couple of whacks with the scissors and you'll have more foam thingies than you can ever eat.
Keith
One thing's for sure: If you use the pink ones your headset is less likely to be stolen!
