Venturi Suction
Venturi Suction
I had one of those revelations today that happen every know and then. I have an IFR C170 with DG and AI driven by venturi suction (My first experince with a venturi system). Down wind abeam the numbers, I pulled the throttle back and happened to glance at the suction gauge (I have flown the airplane for over 200 hrs and must admit this is the first time I noticed). The suction had dropped off to zip. As I reapplied throttle the suction began to rise again. I had not previously realized how much the prop blast affected the suction being produced by the venturi. I assumed if I was moving forward throught the air at 60 MPH + the venturi would be producing sufficient suction.
Is it prop blast aiding suction, or is an idling propeller tending to block the venturis? Maybe some of both? (I really don't know, I'm asking the question.)
Regardless of the cause, it does happen. This is one of the reasons I installed an SVS backup manifold vacuum system. When on, the system uses a flapper valve arrangement to take vacuum from the strongest of two sources. When you close the throttle, the venturi suction backs off, but at the same time the manifold suction increases and takes over. I don't think it was specifically intended to be used this way, but I can find no prohibition against it.
