Well, I should not post after working all day and all night. My synapses sometimes take shortcuts under those conditions. (I posted that msg at a ridiculous hour and apologize.)
Best glide speed, does indeed, provide best distance for loss of altitude in still air.
Kevin, those are good questions.
Firstly, it's important to remember that the Owner's Manual not a Pilot's Operating Handbook. It is not an "approved" document, nor is all the performance-related information contained therein, (although some approved-data contained in the Approved Flight Manual (AFM) is repeated there.)
I believe the take-off-climb recommendation of 88 mph makes the assumption of a standard day, sea-level takeoff.... which would agree with the data contained in the performance section as well as in the AFM.
The recommended entry-speeds in the limitations section are combined with the weight limitations of the utility category, and Va (normally computed at gross wt.) would in most cases be a greater, not lesser, speed, (At reduced weights, aircraft experience increased limitations on manuevering speed, therefore speed must be reduced. This is because Va is the speed at or below which aircraft will stall and relieve flight-load-factors before full/abrupt control movement will cause permanent structural damage. Since aircraft stall at lower speeds when lighter, their manueving speed must also be reduced accordingly.)
The figure of 115 mph for Va was derived from the FAA Type Certificate Data Sheet, which (curiously, for all Cessna 170's, ragwings, A and B models) is stated to be 115 mph or 100 kts. I find that curious due to the obvious differences between the 170 wing structure and the structure of the later, more similar, A and B models.
I believe that Cessna is merely making the recommendation of 115 mph as an entry speed for the approved aerobatic manuevers listed, and that they are not claiming that 115 mph is an equivalent "Va" at those weights.
Similarly, the seaplane speeds for those manuevers is computed at a wt 75 lbs heavier and might lead one to feel one could develop a guide or graph, but I believe that any such method might not be accurate considering that the seaplane has additional structural considerations lacking in the landplane. The AFM tells us that the seaplane Va is 105... regardless of Cessna's differing recommendations for those maneuvers... notice that Cessna ignores seaplane Va in both directions, recommending 100 mph for steep turns, but 110 for lazy 8's/chandelles.
As for "best glide" speed.... while Vy is not always equivalent to best glide in all aircraft, it is a good approximation in this one. Likewise "minimum sink" speed might be comparable to best-angle (Vx) which Cessna indicates to be 76 mph in the takeoff-distance charts (which is approved data, also found in the AFM). Therefore, at flaps zero, gross wt, standard conditions, I believe 76 mph is equivalent to Vx, and 88 mph is equivalent to Vy. At flaps 20 (B model) 67 mph is best angle.
I've written this after a nights rest and hopefully it is more reasonable.
