I wondered how long it would be before my follies showed up on the forums… I wasn’t in a hurry to post it, I still get sick thinking about it. But, maybe someone will learn something from my mistakes.
First, the synopsis the NTSB published has a few errors. The airplane didn’t turn hard right as stated. Below is what I filled out on the FAA accident report:
“There was a private jet, a C172 and a Bonanza ahead of me for take-off and another private jet behind me. The 172 waited for a minute or so before taking off behind the private jet. The Bonanza took position as the 172 was rolling and started rolling as soon as the 172 lifted off. I made my call on the CTAF and entered the runway shortly after the Bonanza had lifted off. I lined up on the center line and began my take-off roll. As the tail came up the airplane veered sharply to the left. I applied right rudder and brake but the airplane continued to veer left off of the runway. I pulled power but the airplane nosed over shortly after leaving the runway and the prop struck the ground. The airplane slowed considerably before the nose dug in and the airplane did a slow flip over the nose and landed on its back.â€
After having some time to think about it and talk to a few instructors with a lot of TW time I have come to the following conclusion about what happened…
I had just purchased the airplane the day before and checked out with a CFI at an airport with an altitude of 900 feet or so. I flew the airplane home and both stops along the way were at low altitude airports without incident. I had a mental picture of the view out the windshield at take-off and landing that included a visual speed reference.
Taking off from Loveland at 5000 feet I probably lifted the tail a little too fast with too little airspeed. At that point gyroscopic progression caused the airplane to veer left and there was not enough rudder authority to correct. There was enough lift in the wings to make the right brake in-effective. I pulled power and the airplane nosed over when it hit the dirt & grass.
The winds at the time were light and variable. It is possible that a small cross-wind or tail-wind gust contributed but I believe that the GP was the main factor.
I had a couple of opportunities once the gyroscopic progression turned the plane left to save the aircraft. First, by pulling power I removed the thrust helping to pull the airplane forward. When I did this the airplane wanted to slow and with the center of gravity already to the right it helped keep the airplane turning left. There was nothing off of the side of the runway to hit, just flat grass and dirt. If I had kept on the throttle the rudder would have soon had enough airflow over it to allow it to control the airplane and I could have just lifted off from the grass. Very ugly and embarrassing but no damage. Obviously this tactic would not be an option if there had been obstacles to hit.
Second, at the point I pulled the throttle I could have planted the tail wheel and the tail wheel would have helped with directional control. I didn’t have enough airspeed to fly so pulling back on the elevator would not have caused the airplane to lift off. I believe the end result of this would have been no damage or maybe a low speed ground loop that bent a gear leg and even in the worst case tipped and bent a wing tip. Still ugly and embarrassing but better then what happened.
When I exited the runway the power was off and the tail was up. The dirt and grass provided enough resistance to start the airplane leaning forward. Once the prop struck dirt the nose lowered more and a very slow motion flip followed. At one point I thought that it was going to stop and go back on it’s wheels but no such luck.
Immediately after the accident I had a major case of denial. I figured that the parking brake issue must have gotten me (yes that was still installed) or the airplane had a bad alignment problem. But as I thought about it more I didn’t have any trouble with tracking previously with the airplane. The brake issue couldn’t have been it because I had no problems taxiing or tracking the center line with the tail on the ground. Besides I could distinctly remember the right rudder moving freely to the floor. Reality sucks!
It’s always bad when you wreck an airplane. The only bright side to this one was no injuries. But totaling a classic because of a series of rooky mistakes is pretty hard to swallow. Not sure if I will consider buying another one or not. Either way It will be a few years of renting before the insurance rates come back down to where I can afford them..
If anyone is looking for a project or parts airplane here is the link to the insurance company auction -
http://www.aigaviation.com/aviationsalv ... ano=N2232D
I would sure like to see it go to someone who would be able to re-build it instead of just being parted out but that’s out of my hands now.
