oil Quick drain
Posted: Mon Dec 29, 2008 2:16 am
by tailspintommy
Can a oil quick drain be installed on a Cont. C-145-2 engine. Anyone have a P/N? Thanks. Tailspintommy
Re: oil Quick drain
Posted: Mon Dec 29, 2008 4:34 pm
AeroQuip PN: AE80666H or Saf-Air Pn: S1000 (or Spruce PN: 07-00880) about $64.
It's a 1-inch X 18 (thread pitch) drain valve.
(You don't need the anti-seize)
Order here: http://www.aircraftspruce.com/catalog/e ... irsump.php
Re: oil Quick drain
Posted: Thu Jul 01, 2021 2:04 am
by dstates
Mine was leaking so I just received a seal kit for it from McFarlane. Kit number is S1000-K. Spruce also sells them but were out of stock this week.
I spoke to Saf-Air and asked for any installation info and I got this exploded view and the recommendation of anti-seize.
I’m looking for a torque spec for it. I found in a Continental SB a torque for “Plug with crush gasket” for all models of 15.8-17.5 ft-lbs. Does that sound like the right torque for this drain valve?
S1000 DWG ASSY.pdf
Re: oil Quick drain
Posted: Thu Jul 01, 2021 3:35 am
by dstates
Here is the quick drain disassembled…
Re: oil Quick drain
Posted: Thu Jul 01, 2021 6:17 am
by hilltop170
Table of proper crush washer tightening specs presented in this EAA video;
https://www.eaa.org/videos/995217327001 ... 2b01JNr1rM
Re: oil Quick drain
Posted: Thu Jul 01, 2021 9:47 am
Yes, it sounds like the right torque. Nice information Richard posted from EAA but the correct torque would be either from Continental Found in M-0, a Lycoming manual if you have one of those engines or the valve manufacturer.
Re: oil Quick drain
Posted: Thu Jul 01, 2021 2:16 pm
Following-Up on Bruce’s comment: Edit> The EAA video / chart posted by Richard is the Lycoming procedure, so if you have a Lycoming engine that would be appropriate (and would likely be helpful if you are out in the “field” without a torque-meter/wrench.)
The Continental M-0 document may be found in our Mx Library by Assoc’n Members: viewtopic.php?f=29&t=13635
The specified Torque-Chart for all fasteners, including those utilizing CRUSH GASKETS, will be found in Appendix “B”, Page B-6. For example, many of the 3/4” and smaller crush gaskets are specified at 190-210 Inch-lbs,… while the 1-3/4” nut/gasket such as the Oil Screen is specified at 500-520 Inch-lbs. (Note that equates to 43 ft-lbs…but that the instructions for the STC’d Tempest/FM-Enterprises Adaptor is 60-ft-lbs.)
Members are encouraged to download the M-0 pdf and read it…. (worth an Associates’ Degree at most Junior Colleges). :wink:
Note: Many times there is confusion by Participants here at the Forums as to why they have difficulty downloading documents and/or accessing the Mx Library, listing Ads in the TradeMart, etc. This is because only Members of the Int’l Cessna 170 Assoc’n (who Hosts this Discussion Forum) may access those areas reserved for Members Only. If you are only a “Participant” having free-access to these Forums you may wish to Join the 170 Assoc’n to gain full Forums privileges. You do not have to “own” a 170 ..or any airplane for that matter… and may Join at our Home Page: https://cessna170.org/
Re: oil Quick drain
Posted: Thu Jul 01, 2021 3:10 pm
by dstates
Thanks, George. I was wondering why I couldn't find the torque limits service bulletin on Continental support web page. It looks like they moved that torque info from the service bulletin to an appendix in the maintenance manual.
