Winter Flying / Engine Cooling
Posted: Thu Jan 15, 2009 11:07 pm
by bweyers
Before I had my 170, I owned a Cessna 120. When flying in the winter, I blocked parts of the cowling to raise oil temperatures. The baffling on my 52 170b is very different than the 120 so I'm not sure if I should use the same strategy. The oil temp guage is very original so I don't have a temp reading but its certianly not up to where it is in summer months.
Any thoughts or suggestions would be appreciated....
Bill
Re: Winter Flying / Engine Cooling
Posted: Fri Jan 16, 2009 12:26 am
by Brad Brady
bweyers wrote:Before I had my 170, I owned a Cessna 120. When flying in the winter, I blocked parts of the cowling to raise oil temperatures. The baffling on my 52 170b is very different than the 120 so I'm not sure if I should use the same strategy. The oil temp guage is very original so I don't have a temp reading but its certianly not up to where it is in summer months.
Bill
You can block the pan cooling hole with duct tape......will help, but not much..Brad
Posted: Fri Jan 16, 2009 12:29 am
Bill,
Use the same strategy as you used on your 120. There are several threads here talking about this. Some have pictures of home made as well as stock baffles. Here are a few:
http://www.cessna170.org/forums/viewtop ... ffle#p8822
http://www.cessna170.org/forums/viewtop ... nter+plate
http://cessna170.org/forums/viewtopic.php?t=3110
