voorheesh wrote:... My landing and taxi light are off the same switch. The switch to the right is disabled. Would anyone recommend splitting the 2 lights and enabling the right switch?
I take it that you have a non-original panel equipped with a double-pole switch that is ON-OFF-BOTH/ON ? with the position to the right being both taxi and land lite on, and position to the left as taxi only? (or...vice-versa?... perhaps you meant it the other way?)
Cessna had several ways of providing taxi/land lights. The most common (in airplanes other than the ragwings) was a single switch with double poles, wherein one position was OFF, one was TAXI light only, and the last position was TAXI AND LANDing lights BOTH ON.
There is nothing "wrong" that I can see with seperating the land and the taxi lamps into separate circuits so that one OR the other could be energized. But I beleve most folks will find it "more illuminating" to be able to energize both SIMULTANEOUSLY as well. If one were to completely seperate the two circuits and utilize two separate switches that could be accomplished.... but at the expense of complicating cockpit switching/placarding a bit.
When Del and myself altered my land/taxi light system we kept the original OFF/TAXI/BOTH switching-scheme but separated the electrical circuits so that each had it's own circuit breaker. If I wished to operate only the LAND lamps I can simply disable the TAXI circuit breaker and place the switch into the LAND position.
So, if you wished to retain your present (or original) switching/placarding set-up.... all one would have to do is provide seperate circuit breakers for the two lamps and use solenoids. Here's a schematic of what we did to my airplane.
(The factory original switch (OFF/TAXI/BOTH) and placard were not altered. The land lamps remained GE-4509 and the taxi lamps were changed to 60-watt GE-4461, which have fresnel/fog lenses. The result is that while in taxi-only mode my electrical demand for the two lamps is less than previously (120-watts versus 200 watts). This is a much more visible lighting system for traffic-pattern work than previously due to the dual lamps being so widely seperated. Of course with all four lamps simultaneously on, the demand is much higher, 320 watts....but I only use that level of brilliance for the short period of short-approach and landing. I switch back to taxi-only after roll-out.)
Anyway, what I am suggesting is that is not necessary to install dual/quadruple lamps to utilize the same wiring schematic and thereby seperate the two circuits without having to alter your cockpit switch/placard.
Dual Land Taxi Lites DWG.pdf
"Trip Free" circuit breakers will "trip" regardless of whether their mechanisms are held to the "on" position. They are preferred, in my opinion, but they cost more. (A circuit breaker which is restricted, such as when baggage or cargo is inadvertently laid against them will not protect a circuit.)
Holding a non-trip-free circuit breaker to prevent it's tripping is patently dangerous, in my opinion. If a mechanism requires that procedure then it is improperly maintained and/or designed and/or the wiring circuit is inadequate, and should be corrected.
I do not believe circuit breakers are "safer" than fuses, per se, but they are definitely more convenient. Corrosion will damage both systems equally. But fuses will almost always perform more reliably than circuit breakers in an overload-condition. (Although they have higher rates of failure in non-overloaded conditions, usually due to vibration. Fuse are definitely more difficult to re-set in flight and at night... but.... remember? we are not supposed to be doing that!
Would someone remind me what system is so important that a blown fuse/circuit-breaker MUST be reset inflight?
Landing gear? Nope. USe the alternate system or land gear-up. Better than an inflight fire.
Communications? Nope. Use the alternate system or continue per the FARs.
Navigation? Perhaps. But only if wx is widely-spread low-ifr. A vfr alternate is preferable to resetting a circuit. (As my old flight instructior once told me, "If you absolutely MUST have a radio (to survive) then you'd better not go, because that is when it will quit." Keep in mind that if your navigation radio system pops a fuse or c.b., then it's very likely a bad scenario within the radio and it won't work if re-set anyway. Are you
sure you want to re-set it? Does your magnetic compass still work?
(I know. I know. Most of us will try at least one re-set. But that is the reason and purpose of this Safety Item thread: Think! How important is that circuit
in reality?)
(And ....isn't this a great reason to carry a portable radio and/or GPS?)
