8.00-6 tire ply rating?
Ryan Smith
Re: 8.00-6 tire ply rating?
Post by Ryan Smith »
Fair enough. Not being overly familiar with the mechanics of aircraft wheels, that makes sense that they would be split rim. I saw some tubeless Goodyears on Aircraft Spruce and was curious.
gparker
Post by gparker »
Thanks Bruce and Aryanna. I will let you know how they do, although I suspect I won't be able to tell the differed from my old 6 ply tires.
1956 170B N3457D
SN 27000
Denham Springs, LA
In order for a split rim to hold air it requires a sealing O-ring at the split. Standard Cleveland wheels for our airplanes are not intended for tubeless tires.
Ryan Smith wrote:Please forgive the dumb question, but assuming a 170 with Cleveland wheels (if it matters), will that wheel support both tube and tubeless tires? Any advantages/disadvantages to running either? I assume perhaps that with tubeless tires, there is a possibility of breaking the bead on a hard landing and blowing a tire, quickly ruining your day.
Cessna/Goodyear introduced tubeless tires in Oct. 1958 as if they were the best thing since sliced bread. But it appears they were on their way out within two years. Apparently they didn't hold air well in cold weather.
In this old thread the question was whether it is legal to install 6-ply tires since the TCDS requires 4-ply rated tires. Here's the applicable section of TCDS A-799:
But note the highlighted section at the bottom of this screenshot. These tires are what are certified to go on Goodyear rims. Most of us have long since replaced the Goodyear rims with Cleveland wheels using STC SA13GL or a field approval. The TCDS data here no longer applies; it has been superseded by the Cleveland STC or a similar field approval. The Cleveland STC gives no guidance regarding tire ply rating. But Cleveland's website shows this for our 40-97A wheels:
So the question now becomes, "Is it legal to install 4-ply rated tires on Cleveland rims?" 8O
