trim
trim
Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
lets say you have 2 aboard, with a half bag of fuel.
Re: trim
Knots ?ghostflyer wrote:About 65 kts.
74.5 MPH.
Re: trim
Which model 170?T. C. Downey wrote:Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
Re: trim
There is only 1 model 170, the rest are 170-"A"s or 170-"B"sgahorn wrote:Which model 170?T. C. Downey wrote:Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
George I am surprised you didn't know that
- Poncho73
Re: trim
Just wondering...why would you need to roll your trim "all the way up"? Not being smart, but what is the issue? FYI, I've never needed maximum trim, in either direction, including max loads on my 48T. C. Downey wrote:Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
Re: trim
170A, O-300-D, 76-55 prop, 2 people, 18gal, idle power, full nose up trim, stabilized descent from 3500'msl;
Flaps up, 67mph, 600fpm descent
Flaps down, 65mph, 800fpm descent
Re: trim
T. C. Downey wrote:There is only 1 model 170, the rest are 170-"A"s or 170-"B"sgahorn wrote:Which model 170?T. C. Downey wrote:Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
According to the TCDS there are three models; Model 170, Model 170A, Model 170B.
Re: trim
well just tried the scenarios given and it's still 65kts. But I have a different engine up front and a the aircraft weights a a bit more . It was a stabile descent at just under 500 ft a min .
Re: trim
OK then,..... what size bag?T. C. Downey wrote:There is only 1 model 170, the rest are 170-"A"s or 170-"B"sgahorn wrote:Which model 170?T. C. Downey wrote:Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
Re: trim
OK then,..... what size bag?gahorn wrote:[
I'll give ya a pass, for the short answer.
Re: trim
Well, I did it today JUST FOR YOU, Tom....
...half fuel, Jamie and I, zero flaps, full nose up trim, idle power....it settled at 60 mph indicated. (1K MSL, 90 degrees F, baro 30.10)
