_____________________________________________
Let’s Fly to Tehachapi (Tah-HATCH-ah-pee)
By
Don Harrell
What is the best route? It actually depends on hour definition of “bestâ€. If you are comfortable on direct routes up to 11,000 feet, over some desolate territory, and rough terrain, then you will be able to save a few minutes. Personally I prefer to use the lowest passes, fly down valleys looking up at the peaks, and follow roads or railroads. In other words staying low and close to some form of civilization just in case. My suggested routes to Tehachapi will follow this thesis but there are many equally easily flown ones.
Here are some things to remember on the way:
Hypoxia. We older folks are more subject to hypoxia than we used to be. It is a sneaky robbery of our mental processes. So subtle that some people refuse to admit that they can be or are affected, so read up on it. Some of the popular beliefs about how to determine its onset are not reliable!
Water. It is easy to become dehydrated out here in the hot summer. Carry at least four one-quart bottles of water. Two can be refilled and frozen each night and the others cached for emergency use. Don’t just carry it around, DRINK IT!
Density altitude. Learn how to use your E6B to compute density altitude. Both takeoffs and landings are affected, but we seldom talk about landings. The higher your altitude, the higher your touchdown speed at a given indicated airspeed. Your indicated approach airspeed should be he same at any density altitude, but the runway will be whizzing by faster at the higher density altitudes. Don’t let that confuse you. Be ready for rapid zigs and zags. Stay on the rudder pedals.
On takeoff do not try to force it off. Let her run. Most high altitude airports have runways long enough to get airborne easily. It is the rate of climb you have to worry about once you get out of ground effect. Rate of climb can easily drop to 100 feet per minute or less on a really hot day. In that mile and a half a lot of tall cactus plants, telephone wires, or communication towers can pop up in your windshield. Plan ahead.
Don’t let any of these ramblings deter you from the trip. But please do keep them in mind. If you can spare a few hours, think of stopping at a high airport on a hot day and taking an hour of dual. It might eliminate a lot of nervous tension.
Some specific routes for your consideration will be described in the coming months. I am planning on describing rather detailed routes with what I call “entry points†at El Paso, Albuquerque, and Cheyenne. Let me know if you think a route further north will be useful. Come out one way and return a different way for more enjoyment. Have a good flight. Please feel free to call me if you want to discuss the trip. My number is in the directory.
Don Harrell
