Jean-Michel,
Welcome! You're following in the footsteps of the legendary Antoine de Saint-Exupe´ry to Dakar. Should be an interesting experience. I'd be fascinated to hear more about general aviation flying in Senegal.
At the risk of sounding like a traitor, from a maintenance standpoint I'd suggest you consider a Piper. Take a look at the list of registered aircraft in Senegal
here. You'll find that Pipers far outnumber Cessnas. So first, you're more likely to find maintenance technicians that are familiar with Pipers. Second, Piper corrosion-proofed their aluminum aircraft much better than Cessna did. Based on the coast corrosion control is going to be a large part of your preventative maintenance. Whatever aircraft you purchase get familiar with Corrosion-X, Boeshield, and ACF-50.
The other aircraft I thought of was something from Aerospatiale -- a Rallye, Tampico, Tobago, Trinidad or from
Robin -- thinking getting parts for these would be much easier in that part of the world than for a C-170. In any case, it appears finding something powered by a Lycoming would be easier to maintain in Senegal. But if you're set on a taildragger what about a PZL Wilga?
P.S. What's with all the De Havilland Dove's in Senegal? I count ten that are registered in Senegal -- three flying, two destroyed, and five scrapped. Is that where Doves go to die? They even have a De Havilland 89 Dominie (military version of the Rapide) in the registry. Now that would be an interesting restoration project. ... Or, if you're very ambitious, there is a scrapped Lockheed Constellation waiting to be restored there.
