Bruce-
This picture has been posted several times before on similar threads.
I originally built the top panel out of 1/8" aluminum sheet using the panel overlay as a pattern with hand-drilled holes and post lights in 1978 to equip 15D for basic instrument flight so I could get my instrument rating and start using the full potential of the plane. It also got a new King Silver Crown radio package at that time consisting of KX170B nav-com with KI209 glidescope nav head, KR86 ADF, KT76 transponder, as well as leaving the existing Cessna Nav-Com 300 in place as an emergency-only backup.
In 2007 the panel was upgraded again with the Garmin package, Icom, and digital instruments. I left the ADF installed because the room was there. I have flown it IFR ever since 1978 and have found the layout works very well. The turn coordinator in the lower center hole is just barely short enough to clear the control column but it does.
My first instructor who is now a senior Captain wth Southwest Airlines taught me to never fly into deteriorating conditions, ice, thunderstorms, or fog. I still use that philosophy religiously 39 years later and have never had a bad experience flying IFR.
Someday I would like to replace the original plastic overlay with one that goes all the way across between the radio stacks.
An Aspen PFD would fit very nicely in the center two holes and would give lots of redundency plus ADHARS info. The lower side of the Aspen is only about an inch or two deep and would clear the control T with lots of room.
