Horizontal Stabilizer Boots
I would like to replace the rubber boots on my horizontal stabilizer. Does anyone know who is selling them nowdays?
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Re: Horizontal Stabilizer Boots
You can get the generic flat material several places. The only source I'm aware of for the extruded boots is Textron. Of course there may be vendor NOS sources as well. Just bought a pair for a 180K, $171 each.
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Thanks Del. A couple questions. Do you think the same part number fits the 170 HS? How long are they? What type of adhesive are you planning on using? My old ones are proving very difficult to remove. Whatever they used to glue them on has really help up over the years.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Yes it fits a 170 stab, It is 68 inches long. Use 1300L adhesive per the instructions, just like installing a deice boot
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Guys, has anyone ever tried to remove the boots that were glued on? The paint stripper and Hostsy we are using doesn't seem to touch the old boots on my plane. I have no idea what they were glued on with. Any suggestions?
1952 170B
N8180A s/n 25032
N8180A s/n 25032
- sfarringer
MEK will soften the adhesive and a plastic scraper for added encouragement.nippaero wrote:Guys, has anyone ever tried to remove the boots that were glued on? The paint stripper and Hostsy we are using doesn't seem to touch the old boots on my plane. I have no idea what they were glued on with. Any suggestions?
Thanks David. I will try some MEK and more elbow grease as soon as the weather improves a little.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Just wanted to close the loop on this. I was able to get the boots off after a lot of elbow grease. The MEK would not penetrate the rubber or the edges. I ended up using a heat gun and a putty knife to peel the rubber. It came off in small strips. Once the rubber was off I used MEK and a scotch brite pad to clean off the rubber adhesive. It took a lot of work but know we can proceed with prepping for paint.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
wingnut wrote:You can get the generic flat material several places. The only source I'm aware of for the extruded boots is Textron. Of course there may be vendor NOS sources as well. Just bought a pair for a 180K, $171 each.
Question, do they come in this shape or you are making the shape with your hand for the picture?
Does this has to be installed by a mechanic or the owner is ok to do it?
I’m going to “jump in” and suggest that although this looks sufficiently simple that a talented owner can accomplish the task... it does not fall under Preventive Maintenance and should be at least supervised/signed-off by an A&P. Although some types of leading edge tapes/boots claim no FAA approval is required, I would want as a minimum a “minor alteration” entry by an A&P if a non-Cessna part is used.motoadve wrote:wingnut wrote:You can get the generic flat material several places. The only source I'm aware of for the extruded boots is Textron. Of course there may be vendor NOS sources as well. Just bought a pair for a 180K, $171 each.
(I’m thinking of the WD Thompson (Cessna Test Pilot) story of how critical a minor alteration to the horiz stab leading edge on a particular airframe became and led to a stall/spin that was almost unrecoverable, which would encourage me to use only the Cessna PN.)
Page 27, FIg.14, Item 59, PN 0332136-4, Abrasion Boot is found in the 170-B IPC.
For the guys who installed the abrasion boots, what is the trick to make it look smooth on the round portion of the horizontal stab?
Nippaero, those leading edges look to be in very good condition. It’s my personal opinion that leading edge abrasion boots are an advisable “evil” only if you are operating on gravel or unimproved rocky surfaces. On ordinary turf or paved runways they are not helpful and they become an added maintenance requirement which can be avoided, obviating concerns about potentially altering leading edge aerodynamic shapes. (Minor leading edge alterations can be detrimental to in-flight handling.). I consider them a “band aid” I try to avoid, despite the fact that 80% of all my operations are from unpaved surfaces.
I am installing the Cessna part, which I think if it changed in-flight handling, it would have never been FAA certified.
Probably because of this certification is why I have to pay $350 for two pieces of rubber.
