What is the impact on the engine flying at lower rpm say 2000 rpm for 2 hours? I usually cruise between 2350 and 2450.
I'm talking about summer trip temps. but what about cold outside temps. like winter stuff
Any input would be appreciated.
Bob
gahorn wrote:You can fly with any power setting you wish, including 2000 rpm. The green arc is the "normal" operational range for cruise. It isn't binding. If it were, then Cessna certainly would have boo-boo'ed publishing all that cruise performance data at 2100 rpm, and also notice that the seaplane actually has 2000 rpm performance charts listed in the Owner's Manual.
The green arc has nothing to do with carb heat use, although that was an "ad hoc" recommendation by many CFI's, as it was a convenient reminder to inexperienced students. (To avoid excessive carb heat usage and it's associated overly-rich fuel conditions, Joe typically just relies upon a stuck valve to reduce his rpm for slower cruise speeds, although he generally makes up for it on approach.)
Just to be nitpickin'....flyguy wrote:Now here is a bone to chew on! Putting "HOT AIR" through the induction system does richen the mixture but also will, if used for an extended period of time, increase the internal temperatures of the mill. Leaning this already hot fuel/air mixture could increase the internal temperatures even more.
Now operating the O-300 at 'low' rpm. It will increase cht and egt a little above normal but within specs. Long term effects may not show up before nearing run-out, but air-cooled engines work better with lots of cooling air going through them. One of the reasons the O-300G engine had less than the stellar sucess it deserved () was operators were afraid of 3100 rpm at cruise and persisted in turning around 2550rpm which is in mid range for the C145/ O-300. This limited the horsepower of the "G" and caused overheating of cyl heads. Consequent cracking of the heads gave the engine a bad rap. Just try to avoid shock cooling those "hot heads" when operating at low rpm settings for a long period of time. (No, I ain't talking bout you Joe!)
