Brake Pedal Spring
Brake Pedal Spring
My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
Is the spring broken or does it not exist in the first place?
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
1956 Cessna 170b
Nanaimo, BC Canada
Re: Brake Pedal Spring
It is broken. Both pedals have a spring. The spring does not really return the pedal to neutral but keeps tension on the cable. A spring on each more or less balances each other out, another reason the pedals won't really center with 2 good springs.
You should obtain an Illustrated Parts Catalog (IPC) for your airplane if you’re going to work on it. It’s simply a MUST HAVE.reecewallace wrote:My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
I downloaded the Cessna 170 parts catalog (255 pages long). It's from 1956. This the right one?GAHorn wrote:You should obtain an Illustrated Parts Catalog (IPC) for your airplane if you’re going to work on it. It’s simply a MUST HAVE.reecewallace wrote:My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
1956 Cessna 170b
Nanaimo, BC Canada
If you have a B-model...Yes.reecewallace wrote:I downloaded the Cessna 170 parts catalog (255 pages long). It's from 1956. This the right one?GAHorn wrote:You should obtain an Illustrated Parts Catalog (IPC) for your airplane if you’re going to work on it. It’s simply a MUST HAVE.reecewallace wrote:My left brake pedal has a spring to retract it back to neutral, but my right pedal does not.
A glance at the pages 101 and 101A would have answered your question on rudder return springs.
- DaveF
Search the forum for info on rudder return springs. There are a few tips on how to make the replacement job easier.
The Rudder Return Springs part #s are 0310196-3 right and 0310196-4 left respectively from the 170 catalog. However, can't find em on Aircraft Spruce Canada.
Any other reputable sites which ship to Canada?
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
1956 Cessna 170b
Nanaimo, BC Canada
Although Spruce sells some common Cessna parts, they are not a source for most factory parts.reecewallace wrote:The Rudder Return Springs part #s are 0310196-3 right and 0310196-4 left respectively from the 170 catalog. However, can't find em on Aircraft Spruce Canada.
I Suggest you seek them from a Cessna distributor. They used to be some of the most reasonably priced parts Cessna sold, but now they are about $32-$43 each: https://www.cessnaparts.com/?s1=0310196 ... arch+Parts
- hartisja
Re: Rudder return springs
I have a 48 170 model
My parts catalog on page 95 shows the springs, but does not call out the part numbers.
Are the part numbers referenced above good for my model (0310196-3/4), or are they different?
- sfarringer
- mit
- dstates
Here's one thread...
viewtopic.php?f=24&t=15024
