Aft fuselage inspection panel
- Poncho73
On an older post, George Horn lists some recommended mods. One was to add an aft fuselage inspection hole for the aft rudder cable area. Has anyone done this that can post a picture? I was looking at my airplane and I couldn’t establish a good spot.
Re: Aft fuselage inspection panel
There are Cessna Service Kits for tail inspection ports for C-180/185s but I never heard of one for a 170. I would definitely be interested in one if they are out there.
- Poncho73
I think George implies it’s done in accordance with the Cessna structural manual standards but I’d really like to see one first.
HUh...? I DID..? What was I drinkin’...?? Errr..I mean THINKIN/...??
Are we talking about the same george? (Oh my Gawd...What monaster have I created...??)
- mit
I don't care who you are that's funny!GAHorn wrote:HUh...? I DID..? What was I drinkin’...?? Errr..I mean THINKIN/...??
Tim
- cfzxo
Hi Richard, I had the access service kit for the 180 - 185 and tried to make it fit on my 55 170b, for access to the pulleys in the tail cone but it wouldn't line up properly to be of any use. I have a picture here somewhere of an access panel that was put on the rear left side. I tried to have a Dar design one based on the photos I have. project never got completed as the individual up and retired. looks like a simple mod, but to be legal not so simple.
Thanks Bill, the 170 rear fuselage skinnys down a lot quicker in the last bulkhead section than the 180/185 so I understand what you are referring to. It would be real handy to have an access back there but luckily I don’t have to crawl back for the inspections.
That’s what hungry young A&Ps like to do.
I still want to stop in at Terrace and meet you one of these days, Terrace is such a nice little town, have stopped there several times in the past, one of our favorite Canadian stopovers. I turned down four ferry flights this year due to Canada closing all but essential air traffic. I could have elbowed my way thru but I didn’t want to get on Custom’s naughty list. I know more than one pilot who was told to not come back to Canada when they didn’t honor the restrictions Customs instructed them to abide by.
- Poncho73
viewtopic.php?f=24&t=1969GAHorn wrote:HUh...? I DID..? What was I drinkin’...?? Errr..I mean THINKIN/...??
Item 7
- cfzxo
hilltop170 wrote:Thanks Bill, the 170 rear fuselage skinnys down a lot quicker in the last bulkhead section than the 180/185 so I understand what you are referring to. It would be real handy to have an access back there but luckily I don’t have to crawl back for the inspections.That’s what hungry young A&Ps like to do.
Hi Richard, I missed you at the Cody convention, but you are welcome at my airstrip anytime you are passing through. We have lots of room for planes and people. 8 miles north east from cyxt on the Skeena River,
Thanks Bill, looking forward to seeing you. If you have 2 runways with a red roof hangar, I see it on the satellite view. Nice secluded place. Glad you got to fly. Everything is covered with glare ice here in Anchorage, I couldn’t even push my plane out of the hangar.
- cfzxo
Richard, that’s the airstrip.
A-HA!Poncho73 wrote:viewtopic.php?f=24&t=1969GAHorn wrote:HUh...? I DID..? What was I drinkin’...?? Errr..I mean THINKIN/...??
Item 7
Whew! I knew I had a failing memory...but that one had me worried!
Here’s the comment: “ 7. Inspect the rudder cables where they pass through the rear bulkheads in the tailcone. You'll have to either pull them out for inspection, or add an inspection hole to the aircraft per the structural repair guidelines.”
I was NOT intending to imply a particular/existing modification-scheme existed.... I was recommending an inspection of the rudder control circuit...and noting the difficulty.... and that IF one want’s to install an inspection hole to do so in accordance with Cessna’s Structural Repair guidelines. Cessna will allow the creation of inspection holes under certain guidelines contained in the Structural Repair Manual.
- Poncho73
OK thanks George. As others have mentioned the aft area near the rudder cables is tight. I was hoping someone had installed an inspection hole. Judging from the group response it appears no one has....I will go back to the drawing board and have detailed look at whether there is even room. Thanks
Other than a general, the only reason to go in there are to inspect the cable guides and cable condition. Based on your previous work, I would think with snap-on 1/4 drive flex sockets can make easy work at getting to the nuts in that area. On these planes Snap- ons are a must have.
- cfzxo
Jim, those of us with the 1955b models have a steering arrangement past the last bulkhead that is impossible to access unless you remove the vertical and horizontal stab. when I went into it at my last rebuild I found that two fairleads where bent not allowing the pulleys to turn, and who knows when they where last lubricated. I small access hole in this location would make inspections and maintenance so much easier.
