I apologize for asking guys, but I did a search and couldn't find the answer...also not in parts catalog...what size is gascolator drain valve. I think mine is 3/8" NPT...it is the glass bowl type. Mine leaks a little...just enough to be irritating. Want to replace it, or the o-ring, whichever is recommended.
Thanks in advance.
Gascolator Drain
My ragwing has a total of 4 gas drains, two are CAV-110's ( 1/8" NPT) & two are CAV-170's (7/16"-20). Can't remember which is at the gascolator. When I bought the plane, I had some drain leaks. When I went to replace the o-rings, I found the drains themselves badly corroded. I replaced all 4 drains, & kept the old ones (with new o-rings) to carry as spares. They're only about 10 or 12 bucks apiece for new ones.
